Wondering if there is a way to limit notifications that are sent to something X per hour? I have a notification that checks a temperature and if it is below a certain temp then send me a notification, but it is sending me one every 10 mins(polling cycle of the temperature device)
You could put the notification in a script with a delay of 10 min (after the notification is sent). If you trigger a script thatâs already running, it wonât run again (youâll see an âalready runningâ error in the logs).
Otherwise, you might be able to use the last_triggered attribute in an automation as a condition. Youâll have to structure things so that one automation triggers another.
I like the sound of using the last triggered. Looks like that is part of the state, but not seeing a way to use it yet.
In case you havenât found a solution, here is how I did it. The automation basically sends the notification and then calls a script that turns off the automation for 15 minutes:
- alias: 'Sump Water Detected'
platform: state
entity_id: binary_sensor.sump_water_detect
state: 'on'
for:
seconds: 15
- service: notify.notify
title: 'HASS - DANGER: Sump Pump Detected Water @ "{{now().strftime("%H:%M:%S %m-%d")}}"'
message: 'HASS - Water was detected in the sump pump room at "{{now().strftime("%H:%M:%S %Y-%m-%d")}}". The current is {{ states.sensor.sump_water_detect.state }} Amps'
- service: homeassistant.turn_on
entity_id: script.sump_water_notify_rate_limit
script:
sump_water_notify_rate_limit:
alias: Rate Limit Sump Pump Water Detect Notifications
sequence:
- service: homeassistant.turn_off
entity_id: automation.sump_water_detected
- delay: '00:15:00'
Feedback on this rate-limits for group notifications? I did it in group.notify since that seemed like a nice place to add the extra complexity rather than making it fundamental to notify.
