I’m using the Tibber integration, and was wondering if there is a way to limit the update frequency of the real time consumption? Right now it seems like it’s updating every second, which is way more than I need, and it’s also making 24 hour plots very slow (running on a RPi 4 4Gb).
Thanks! I knew there had to be an easy way to do this.
You should then also exclude it from the recorder: https://www.home-assistant.io/integrations/recorder/#exclude
