I’m using Xiaomi aquara curtains and would like to limit the maximum open position. Since the curtains are opening in a 90 degree corner, they are sometimes getting stuck, so I would like to limit the curtain maximum open position just before the corner as a workaround. Currently I am able to open them, but I have to always use the slider to 90% or so. I would like to just be able to click ‘open’ and use google assistant to ‘open the curtains’ without having to state the position (‘open the curtains to 90%’).
The curtains are connected via Deconz and are visible in Home Assistant as ‘cover’. Any suggestions are appreciated, thanks!
haven’t tried it, but I think you can create a template cover, which you can use instead of the original cover. In this template cover set the position to 90% when it is opened.
I think something like this could work:
