I use this Energy Meter and it works great, but getting the data into HA causes some issues.
When I create MQTT-based sensors for the 4-5 values I’d like to see in HA it brings my Pi4 to its knees and I think it’s because all values are updated every second.
Is there an option to limit the upate ratio to 5, 10, or 15 seconds?
There’s no such file thing as an “MQTT read”. Home Assistant acts as an MQTT Client. That means it subscribes to a topic and receives payloads published to that topic. So if payloads are published every second, Home Assistant receives them at the same rate.
If you want to receive them at a lower rate, then you have to reduce the publishing rate. To achieve this, you must have control of the device doing the publishing (and that’s not always possible).
Thanks for the explanation - I have access to the physical device, but don’t understand enough about the ins & outs of the software to be able o make these changes myself at that end.
