Limitless Bridge v6 and White Lights
Does anyone get white lights working with Bridge v6 ?
Only white and v6 !
My white lights are working fine with Bridge v5 but not with v6.
I can control them with app but no effect in home assistant.
Many people seem to have the problem so I just want to know if someone gets this setup working ?
Rgbw is working fine but not white bulbs/strips.
IP is of course correct otherwise rgbw would not work. Etc
My config for reference:
- host: 192.168.10.52
  version: 6
  port: 5987
  groups:
  - number: 1
    type: rgbw
    fade: on
  - number: 1
    type: white
    fade: on
  - number: 2
    type: rgbww
    fade: on
  - number: 3
    type: rgbw
    fade: on
  - number: 4
    type: rgbww
    fade: on
Most important question is, if anybody has a running setup with white buld and bridge v6 ?
Thank you !
Hey ssushi,
Are you still having issues with the white bulbs and v6 bridge?
I just got mine to work yesterday (1st time) and I removed the version and port.
Not sure if this has an effect but I also changed the STA mode settings for the bridge by setting UDP and port 5987.
