Hi guys,
tried to upgrade from 0.38.3 to 0.40.1 to avail of Tado tracking (it didn’t recognise multiple devices with 0.38.x).
If I upgrade to 0.40.1, I lose my Limitless LED:
17-03-22 11:56:24 WARNING (Thread-12) [homeassistant.components.emulated_hue] When targetting Google Home, listening port has to be port 80
17-03-22 11:56:39 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform limitlessled
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py", line 151, in _async_setup_platform
entity_platform.add_entities, discovery_info
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/futures.py", line 361, in __iter__
yield self # This tells Task to wait for completion.
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/tasks.py", line 296, in _wakeup
future.result()
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/asyncio/futures.py", line 274, in result
raise self._exception
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/Library/Frameworks/Python.framework/Versions/3.5/lib/python3.5/site-packages/homeassistant/components/light/limitlessled.py", line 112, in setup_platform
version=bridge_conf.get(CONF_VERSION, DEFAULT_VERSION))
File "/Users/dario/.homeassistant/deps/limitlessled/bridge.py", line 99, in __init__
self._init_connection()
File "/Users/dario/.homeassistant/deps/limitlessled/bridge.py", line 206, in _init_connection
self._socket.recv_into(response)
ConnectionRefusedError: [Errno 61] Connection refused
Also, if I try to downgrade to 0.40.0, it won’t even start Hass (saying it cannot find the scene component).
Any help would be appreciated, thanks!
