so Ive been trying to get this working for three days. i have a mi light bridge v6 and a few lamp in one zone i can control the lamps with my phone via the app no problem but i’m unable to do so via ha, i’ve tried so many different configs but nothing works this is the one i’m running now. has any one an idea of what i’m doing wrong, the ip is right and i can ping towards it as well
light:
platform: limitlessled
bridges:
- host: 10.10.10.15
version: 6
port: 8899
groups:
- number: 1
type: rgbww
this is the error i’m getting but i get none the wiser out of it:
2019-11-16 21:04:38 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform limitlessled
File “/usr/local/lib/python3.7/site-packages/limitlessled/group/commands/init.py”, line 25, in command_set_factory
cls = next(cs for cs in command_sets if
StopIteration
File “/usr/src/homeassistant/homeassistant/helpers/entity_platform.py”, line 150, in _async_setup_platform
await asyncio.wait_for(asyncio.shield(task), SLOW_SETUP_MAX_WAIT)
File “/usr/local/lib/python3.7/asyncio/tasks.py”, line 442, in wait_for
return fut.result()
File “/usr/local/lib/python3.7/concurrent/futures/thread.py”, line 57, in run
File “/usr/src/homeassistant/homeassistant/components/limitlessled/light.py”, line 158, in setup_platform
group_conf.get(CONF_TYPE, DEFAULT_LED_TYPE),
File “/usr/local/lib/python3.7/site-packages/limitlessled/bridge.py”, line 155, in add_group
group = group_factory(self, number, name, led_type)
File “/usr/local/lib/python3.7/site-packages/limitlessled/bridge.py”, line 47, in group_factory
return RgbwwGroup(bridge, number, name)
File “/usr/local/lib/python3.7/site-packages/limitlessled/group/rgbww.py”, line 25, in init
super().init(bridge, number, name, RGBWW)
File “/usr/local/lib/python3.7/site-packages/limitlessled/group/init.py”, line 57, in init
self._command_set = command_set_factory(bridge, number, led_type)
File “/usr/local/lib/python3.7/site-packages/limitlessled/group/commands/init.py”, line 30, in command_set_factory
raise ValueError('There is no command set for ’
ValueError: There is no command set for specified bridge version and led type.
