Hi.
I am struggling with the lights keep coming on Blue rather than white using Home Assistant. They seem to have remembered some state and always default to that. Is there any way I can set the state of the light on startup?
If I use the windows app supplied by limitlessled, it sends a string of hex codes to the light and I think home assistant seems to use JSON commands?
Is there any way to set the default string to send to a light when you switch it on similar to that windows app?
The app produces this report:
Start Wifi Bridge Session…
Send UDP commands to 10.90.11.25 port 5987
Sent: 20 00 00 00 16 02 62 3A D5 ED A3 01 AE 08 2D 46 61 41 A7 F6 DC AF D3 E6 00 00 1E
Received: 28 00 00 00 11 00 02 F0 FE 6B 4B 0F 20 12 A2 2C 7E 00 01 67 01 00
LimitlessLEDWifiBridgeSessionID1 is 67
LimitlessLEDWifiBridgeSessionID2 is 01
IP Address is 10.90.11.25
MAC Address is FE:6B:4B:0F:20:12
Sequence Number is 07
Checksum is 3F
Sent: 80 00 00 00 11 67 01 00 07 00 31 00 00 08 04 01 00 00 00 01 00 3F
Command SUCCESSFUL.
Received: 88 00 00 00 03 00 07 00
Command completed.
So can I configure the string sent to lights?
