Limitlessled not showing up
Greetings everybody,
I started using HassIO a few weeks ago and I am having a blast with it. Everything just works. Everything BUT the LimitlessLED integration.
Before I go on, I really don’t think that this is a binding issue.
I have used the limitlessLED app to check my config and it works fine from both the phone app and the limitlessled EXE.
I even created my own hub using the instructions here (http://blog.christophermullins.com/2017/02/11/milight-wifi-gateway-emulator-on-an-esp8266/) and I had no issues getting it to work. Se eventually my plan B could be MQTT.
This is what I have in lights
light:
  platform: limitlessled
  bridges:
    - host: 192.168.0.201
      groups:
      - number: 1
        type: rgbw
      - number: 2
        type: rgbw
      - number: 3
        type: rgbw
        fade: on
      - number: 4
        type: dimmer
At first, they were showing up under lights, but as I added stuff to my configuration file, they eventually disappeared.
I tried moving the code around with no luck.
I am running
  • HassIO V.68.1
  • PI3
Here’s the full configuration file
homeassistant:
  # Name of the location where Home Assistant is running
  # Location required to calculate the time the sun rises and sets
  latitude: 55.689
  longitude: -63.8671
  # Impacts weather/sunrise data (altitude above sea level in meters)
  elevation: 0
  # metric for Metric, imperial for Imperial
  unit_system: metric
  # Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
  time_zone: America/Toronto
  # Customization file
  customize: !include customize.yaml
# Show links to resources in log and frontend
# introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
  # Secrets are defined in the file secrets.yaml
  api_password: !secret http_password
  # Uncomment this if you are using SSL/TLS, running in Docker container, etc.
  # base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
  # Optional, allows Home Assistant developers to focus on popular components.
  # include_used_components: true
# Discover some devices automatically
discovery:
  enable:
    - homekit
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
  hide: true
# Weather prediction
# - platform: yr
  - platform: openweathermap
    api_key: !secret openweathermap_api
    forecast: true
    monitored_conditions:
      - temperature
      - wind_speed
  - platform: mqtt
    state_topic: "tele/sonoffpow/SENSOR"
    qos: 0
    unit_of_measurement: "W"
    value_template: "{{ value_json['ENERGY'].Power }}"
  - platform: mqtt
    qos: 0
    unit_of_measurement: "V"
    value_template: "{{ value_json['ENERGY'].Voltage }}"
  - platform: mqtt
    qos: 0
    unit_of_measurement: "kWh"
    value_template: "{{ value_json['ENERGY'].Today }}"
  - platform: mqtt
    qos: 0
    unit_of_measurement: "A"
    value_template: "{{ value_json['ENERGY'].Current }}"
  - platform: mqtt
    name: "POW Yesterday"
    qos: 0
    value_template: "{{ value_json['ENERGY'].Yesterday }}"
# Text to speech
tts:
  - platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
light:
  bridges:
      groups:
      - number: 1
        type: rgbw
      - number: 2
        type: rgbw
      - number: 3
        type: rgbw
        fade: on
      - number: 4
        type: dimmer
mqtt:
  broker: core-mosquitto
  username: !secret MQTTuser
  password: !secret MQTTpwd
panel_iframe:
  configurator:
    title: Configurator
    icon: mdi:wrench
    url: http://192.168.0.177:3218
switch:
  - platform: mqtt
    name: "Sonoff4 Switch 01"
    command_topic: "cmnd/sonoff4/power1"
    state_topic: "stat/sonoff4/POWER1"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
  - platform: mqtt
    name: "Sonoff4 Switch 02"
    command_topic: "cmnd/sonoff4/power2"
    state_topic: "stat/sonoff4/POWER2"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
  - platform: mqtt
    name: "Sonoff4 Switch 03"
    command_topic: "cmnd/sonoff4/power3"
    state_topic: "stat/sonoff4/POWER3"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
  - platform: mqtt
    name: "Sonoff4 Switch 04"
    command_topic: "cmnd/sonoff4/power4"
    state_topic: "stat/sonoff4/POWER4"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
  - platform: mqtt
    command_topic: "cmnd/sonoffpow/power"
    state_topic: "stat/sonoffpow/POWER"
    qos: 1
    payload_on: "ON"
    payload_off: "OFF"
  - platform: tplink
    host: 192.168.0.163
media_player:
  - platform: plex
  - platform: yamaha_musiccast
    host: 192.168.0.237
xiaomi_aqara:
  discovery_retry: 5
  gateways:
    - key: !secret xiaomi_aqara_key
weather:
homekit:
  auto_start: False
Found the following in the logs:
2018-05-01 22:03:28 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform limitlessled
File “/usr/lib/python3.6/site-packages/homeassistant/helpers/entity_platform.py”, line 129, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=hass.loop)
File “/usr/lib/python3.6/asyncio/tasks.py”, line 358, in wait_for
return fut.result()
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/light/limitlessled.py”, line 120, in setup_platform
version=bridge_conf.get(CONF_VERSION, DEFAULT_VERSION))
File “/usr/lib/python3.6/site-packages/limitlessled/bridge.py”, line 109, in init
self._init_connection()
File “/usr/lib/python3.6/site-packages/limitlessled/bridge.py”, line 254, in _init_connection
self._socket.recv_into(response)
ConnectionRefusedError: [Errno 111] Connection refused
Thanks in advance guys
Chris
You follow this bit about the ports:
port (Optional): Bridge port. Defaults to 5987. For older bridges than v6 choose 8899.
Petro, YOU ROCK!
That was it.
Looks like that port wasn’t optional after all.
Thank you so much
Chris
