I use exactly the same setting with RGBW bulb in Living room and white in Bed Room, both number 1…however when turning on either only the RGBW bulb in living room turns on. I can turn them on/off, controll features separately on iOS Milight app and 2.4Ghz remote. See my config snipped below. Help appreciated fellas
@Bob_NL & @BarryHampants thankyou guys for your quick response
I have the v6 and I guess the port is 5987. I have tired combinations of version: 2, 3, 4, 5 & 6 with Port: ‘8899, 5987’ only the 6 with 5987 triggered the RGBW light (at least), but all failed to triggered my white lights. I have since read another discussion that has an unresolved white light control issue for v6 bridge
Software version: V1.0.04a-JCY-1
Wifi Workmode: STA
Port ID: 8899 (maybe you have another port. To check it> go to the Ip adress of Milight>Other Setting>Port ID)
Never got limitlessled working, but luckily after finding these instructions MQTT finally works! Also, playing with milight-hub radio settings improved the transmission between the hub and the lights. (Before I had to repeat the messages.)
Does anyone know how to troubleshoot the communication between limitlessled and the hub? Could I netcat to the hub and send REST commands via UDP?
Im succesfull after changing port to 5987 and all led type to RGBWW. I have version 6.
Its quite interesting because on Mi-Light iBox 2 configuration I have port 8899/TCP Server, so box must hear also on another port.
After I change type from RGBWW to RGBW it stops working, so led type also matters.
The screenshot comming from the ip were you have your WIFI controller.
Just entering the ip of the device (user: admin pass: admin) and the go to the options of the image that I put it before.
