It likely is incomplete. I am still searching for some reference to the device being included in OpenHAB and perhaps a better file. The zwave database on his website is still a worthwhile resource.
I used the latest version of python_openzwave (0.4.0.35) and it seems to be working fine:
pip3 install python_openzwave --install-option="--flavor=ozwdev"
New update. Some things maybe not relevant, just documenting for other’s benefit. Summarizing some steps for the sake of typing…
Running a fresh install of Hassbian 1.23. Z wave installed via the Hassbian PIP script. No issues. Backed up my config and SD card prior to doing this.
Stopped HASS. Ran the following commands:
sudo -u homeassistant -H /bin/bash
source /srv/homeassistant/bin/activate
pip3 uninstall python_openzwave
deactivate
exit
Copied my options.xml into the /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config
I dont know if that step is necessary any more or not, but wanted to make sure my security key was included.
Modified the init.py file to get rid of the z wave requirement
Started Hass. Started OK with the exception of this error in the home-assistant.log
2017-08-10 16:36:38 ERROR (Dummy-21) [libopenzwave] notif_callback exception
File “src-lib/libopenzwave/libopenzwave.pyx”, line 494, in libopenzwave.notif_callback
IndexError: list index out of range
Once the front end loaded, I noticed I lost names on all of my 30+ z wave devices, but I did have a cover component.
NOTE: I had done a secure add of the Linear device previously.
I saw how the new Z wave version uses ozwcache_deviceid.xml vs zwcfg_deviceid.xml so I thought I would test out what would happen if I renamed my old zwcfg to ozwcache. So I stopped HASS, did the rename and started up. Hass loaded the front end then promptly crashed with no errors. Front end just wouldnt load.
Ran the restart command and Hass loaded and my device names were back! But…no cover any more! Same traceback error in my log.
In the Z wave configuration page, I now had two components with the same node (the Linear device). One was:
zwave.unknown_id014f_unknown_type4744_id3030
The other was just
zwave._
Then Hass crashed again. No errors. No nothing.
Restarted HASS. Traceback error in log again. Thought I would try and remove and re add the Linear device. So I removed it (after z wave said it was ready), then ran a secure add. Then Hass crashed again.
Log did show this error:
2017-08-10 16:52:52 WARNING (Thread-12) [openzwave] Can't lock controller for command : add_node
So, too unstable. Flashing my backup image back. Progress, but no stability.
EDIT: Hass MIGHT run stable if I would have left the ozwcache file as is, but losing names on 30+ devices would be 2 days of making everything run again.
Copy your zwcfg over the ozwcache, but try removing the linear device from the XML first.
I already rolled back to my working image. Wouldn’t feel good about running that kind of setup 24/7 right now. Will wait for the official version.
Yes, the latest python_openzwave will work, the problem is when you do this:
Then you have to make sure you edit:
homeassistant/components/zwave/__init__.py
and edit:
REQUIREMENTS = ['pydispatcher==2.0.5', 'python_openzwave==0.4.0.31']
line so the version matches. I am pretty sure if you don’t do this, when HA starts it will stick the version of python_openzwave from REQUIREMENTS in the ./deps directory because it wants the exact version. ( == vs >= )
I did update homeassistant/components/zwave/__init__.py
, but I completely removed the python_openzwave
requirement. That entry now looks like this for me:
REQUIREMENTS = ['pydispatcher==2.0.5', ]
I used this sed command in my Dockerfile:
sed -i "s/'python_openzwave==.*'//" /usr/local/lib/python3.5/dist-packages/homeassistant/components/zwave/__init__.py
I’m not using the Dockerfile provided by the project, I wrote my own because I’m not using all the features in the project’s Dockefile.
I had to remove the Linear GDO and re-add it after switching to the Dev branch. It’s working great now. I had to do the same with my Zooz multisensor. It is working great now too.
@firstof9 This morning my garage door was at the 66 error. So I go and check, low and behold there is an update. So I make a copy of my SD card and upgrade. Run the script. The first time it bombed somewhere (did not get a snapshot) and now when I run it I get this …
pi@hassbian:~ $ hassctl stop
pi@hassbian:~ $ sudo -u homeassistant -H /bin/bash
homeassistant@hassbian:/home/pi $ source /srv/homeassistant/bin/activate
(homeassistant) homeassistant@hassbian:/home/pi $ pip3 uninstall python_openzwave
Cannot uninstall requirement python-openzwave, not installed
(homeassistant) homeassistant@hassbian:/home/pi $ pip3 install python_openzwave --install-option="--flavor=ozwdev"
/srv/homeassistant/lib/python3.4/site-packages/pip/commands/install.py:194: UserWarning: Disabling all use of wheels due to the use of --build-options / --global-options / --install-options.
cmdoptions.check_install_build_global(options)
Collecting python_openzwave
Using cached python_openzwave-0.4.0.35.zip
Requirement already satisfied: six in /srv/homeassistant/lib/python3.4/site-packages (from python_openzwave)
Requirement already satisfied: PyDispatcher>=2.0.5 in /srv/homeassistant/lib/python3.4/site-packages (from python_openzwave)
Installing collected packages: python-openzwave
Running setup.py install for python-openzwave ... error
Complete output from command /srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-b4k0vaq3/python-openzwave/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-jilemwhl-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.4/python-openzwave --flavor=ozwdev:
ImportError in : from wheel.bdist_wheel import bdist_wheel as _bdist_wheel
NameError in : class bdist_wheel(_bdist_wheel) - Use bdist_egg instead
<pyozw_setup.OzwdevTemplate object at 0x762c5af0>
Requirement already satisfied: Cython in /srv/homeassistant/lib/python3.4/site-packages
{'include_dirs': ['openzwave-git/open-zwave-Dev/cpp/src', 'openzwave-git/open-zwave-Dev/cpp/src/value_classes', 'openzwave-git/open-zwave-Dev/cpp/src/platform', 'openzwave-git/open-zwave-Dev/cpp/build/linux'], 'extra_objects': ['openzwave-git/open-zwave-Dev/libopenzwave.a'], 'name': 'libopenzwave', 'extra_link_args': [], 'define_macros': [('PY_LIB_VERSION', '0.4.0.35'), ('PY_SSIZE_T_CLEAN', 1), ('PY_LIB_FLAVOR', 'ozwdev'), ('PY_LIB_BACKEND', 'cython')], 'extra_compile_args': [], 'language': 'c++', 'libraries': ['udev', 'stdc++', 'resolv'], 'sources': ['src-lib/libopenzwave/libopenzwave.pyx']}
['six', 'PyDispatcher>=2.0.5', 'Cython']
running install
flavor --flavor=ozwdev
running build_openzwave
Found g++ : /usr/bin/g++
Found gcc : /usr/bin/gcc
Found make : /usr/bin/make
Found gmake : None
Found pkg-config : /usr/bin/pkg-config
Found library udev : True
Found library stdc++ : False
Found library resolv : False
Found library yaml-0.1 : True
Found library libopenzwave : False
Found library python : True
Found library python2 : True
Found library python3 : True
fetching https://codeload.github.com/OpenZWave/open-zwave/zip/Dev into openzwave-git/open-zwave.zip for version 0.4.0.35
Build openzwave ... be patient ...
running openzwave_config
copying openzwave-git/open-zwave-Dev/config/fakro/zws230.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/fakro
copying openzwave-git/open-zwave-Dev/config/fakro/zwrs.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/fakro
copying openzwave-git/open-zwave-Dev/config/fakro/zws12.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/fakro
copying openzwave-git/open-zwave-Dev/config/fakro/zwp10.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/fakro
copying openzwave-git/open-zwave-Dev/config/nodon/crc360xSofremote.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/nodon
copying openzwave-git/open-zwave-Dev/config/nodon/cws3101wallswitch.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/nodon
copying openzwave-git/open-zwave-Dev/config/nodon/msp31xxMicroSmartPlug.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/nodon
copying openzwave-git/open-zwave-Dev/config/nodon/crc3100OctanRemote.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/nodon
copying openzwave-git/open-zwave-Dev/config/nodon/asp3100SmartPlug.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/nodon
copying openzwave-git/open-zwave-Dev/config/nexia/db100z.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/nexia
copying openzwave-git/open-zwave-Dev/config/zipato/RGBBulb2.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/zipato
copying openzwave-git/open-zwave-Dev/config/zipato/zp3102.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/zipato
copying openzwave-git/open-zwave-Dev/config/zipato/vszd2102.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/zipato
copying openzwave-git/open-zwave-Dev/config/zipato/RGBBulb.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/zipato
copying openzwave-git/open-zwave-Dev/config/zipato/MiniKeypad.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/zipato
copying openzwave-git/open-zwave-Dev/config/everspringct/hsm02.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/everspringct
copying openzwave-git/open-zwave-Dev/config/greenwave/powernode6.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/greenwave
copying openzwave-git/open-zwave-Dev/config/greenwave/powernode1.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/greenwave
copying openzwave-git/open-zwave-Dev/config/leviton/vrf01.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/leviton
copying openzwave-git/open-zwave-Dev/config/leviton/rzi10.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/leviton
copying openzwave-git/open-zwave-Dev/config/leviton/vri10.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/leviton
copying openzwave-git/open-zwave-Dev/config/leviton/vrcpg.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/leviton
copying openzwave-git/open-zwave-Dev/config/leviton/vri06.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/leviton
copying openzwave-git/open-zwave-Dev/config/leviton/dzpd3.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/leviton
copying openzwave-git/open-zwave-Dev/config/leviton/dz6hd.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/leviton
copying openzwave-git/open-zwave-Dev/config/leviton/dz15s.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/leviton
copying openzwave-git/open-zwave-Dev/config/heiman/HS1WL-Z.xml -> /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/heiman
error: could not delete '/srv/homeassistant/lib/python3.4/site-packages/python_openzwave/ozw_config/heiman/HS1WL-Z.xml': Permission denied
Command "/srv/homeassistant/bin/python3 -u -c "import setuptools, tokenize;__file__='/tmp/pip-build-b4k0vaq3/python-openzwave/setup.py';f=getattr(tokenize, 'open', open)(__file__);code=f.read().replace('\r\n', '\n');f.close();exec(compile(code, __file__, 'exec'))" install --record /tmp/pip-jilemwhl-record/install-record.txt --single-version-externally-managed --compile --install-headers /srv/homeassistant/include/site/python3.4/python-openzwave --flavor=ozwdev" failed with error code 1 in /tmp/pip-build-b4k0vaq3/python-openzwave/
(homeassistant) homeassistant@hassbian:/home/pi $ deactivate
homeassistant@hassbian:/home/pi $ exit
@penright
Issue this command sudo chown -R homeassistant:homeassistant /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/
Then try again.
Looks like it went without error
pi@hassbian:~ $ sudo chown -R homeassistant:homeassistant /srv/homeassistant/lib/python3.4/site-packages/python_openzwave/
pi@hassbian:~ $ hassctl stop pi@hassbian:~ $ sudo -u homeassistant -H /bin/bash
Running setup.py install for python-openzwave ... done
Successfully installed python-openzwave-0.4.0.35
exit
Ran without errors, even after restarting hass 3 times still getting 66 error. I hope that not the same as order 66.
What does the first line of OZW_Log.txt say?
Just like always the unhandled 66 command. Is there more I could look at to see?
All other Zwave works.
Who do we ask about merging the fixes at open zwave? I found this emial address ‘[email protected]’.
I was wondering if anyone with hass is also member of the the open zwave team. I don’t want to bug them if there is a better route.
2017-08-15 16:14:36.125 Info, Node012, Sending (Send) message (Callback ID=0x01, Expected Reply=0x00) - Nonce_Report - 0x01, 0x11, 0x00, 0x13, 0x0c, 0x0a, 0x98, 0x80, 0x26, 0xe1, 0xa4, 0x6e, 0x9e, 0x47, 0xc9, 0x4e, 0x05, 0x01, 0xb4:
2017-08-15 16:14:36.134 Detail, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2017-08-15 16:14:36.135 Detail, ZW_SEND_DATA delivered to Z-Wave stack
2017-08-15 16:14:36.151 Detail, Received: 0x01, 0x07, 0x00, 0x13, 0x01, 0x00, 0x00, 0x03, 0xe9
2017-08-15 16:14:36.151 Detail, ZW_SEND_DATA Request with callback ID 0x01 received (expected 0x01)
2017-08-15 16:14:36.168 Detail, Node012, Received: 0x01, 0x1d, 0x00, 0x04, 0x00, 0x0c, 0x17, 0x98, 0x81, 0xea, 0x10, 0x06, 0xb9, 0x94, 0x35, 0x9c, 0x15, 0xca, 0x8c, 0x17, 0x5b, 0x26, 0x92, 0x00, 0xb2, 0x18, 0x47, 0x0c, 0x3e, 0x0e, 0xe6
2017-08-15 16:14:36.169 Info, Raw: 0x98, 0x81, 0xea, 0x10, 0x06, 0xb9, 0x94, 0x35, 0x9c, 0x15, 0xca, 0x8c, 0x17, 0x5b, 0x26, 0x92, 0x00, 0xb2, 0x18, 0x47, 0x0c, 0x3e, 0x0e, 0xe6
2017-08-15 16:14:36.169 Detail, Node012, Decrypted Packet: 0x00, 0x66, 0x03, 0xff
2017-08-15 16:14:36.169 Info, Node012, ApplicationCommandHandler - Unhandled Command Class 0x66
head OZW_Log.txt
Should produce: 2017-08-14 18:46:40.176 Always, OpenZwave Version 1.5.2717 Starting Up
or similar. The key is the 1.5.xxxxx version number. If it says 1.4.xxxxx then HA is using the wrong library.
That’s it. So I need to back way to the top to install the beta version?
2017-08-15 13:37:28.347 Always, OpenZwave Version 1.4.2508 Starting Up
2017-08-15 13:37:31.167 Info, Setting Up Provided Network Key for Secure Communications
2017-08-15 13:37:31.168 Info, mgr, Added driver for controller /dev/zwave
2017-08-15 13:37:31.168 Info, Opening controller /dev/zwave
2017-08-15 13:37:31.168 Info, Trying to open serial port /dev/zwave (attempt 1)
2017-08-15 13:37:31.169 Info, Serial port /dev/zwave opened (attempt 1)
I’m not sure why the pip uninstall/install isn’t working correctly.
Maybe @hawk259 has some insight?
Trying to reinstall using the script I did the first time.
Just curious why it was giving me the 66 error before I installed. Now I know to look and make sure it is running 1.5.xxx.
I wonder what it would take for open zwave to put the beta into production. If I understand correctly that would keep us from having to jump through hoops.
It has been sitting on resolving deltas: 83% for a while.
pi@hassbian:~/scripts $ sudo ./ha_openzwave.sh
Open Z-Wave Installer for Hassbian
Modified by Landrash for use with Hassbian.
Remodified by unt1tled for use with Linear NGDZ00-4 (barrier_operator).
Remodified by Paul, for Hassbian .48.1 7/18/2017
Copyright(c) 2016 Dale Higgs <https://gitter.im/dale3h>
Running apt-get preparation
Get:1 http://ftp.debian.org jessie-backports InRelease [166 kB]
Hit http://mirrordirector.raspbian.org jessie InRelease
Hit http://repo.mosquitto.org jessie InRelease
Hit http://archive.raspberrypi.org jessie InRelease
Hit http://mirrordirector.raspbian.org jessie/main armhf Packages
Hit http://repo.mosquitto.org jessie/main armhf Packages
Ign http://ftp.debian.org jessie-backports InRelease
Hit http://mirrordirector.raspbian.org jessie/contrib armhf Packages
Hit http://archive.raspberrypi.org jessie/main armhf Packages
Hit http://mirrordirector.raspbian.org jessie/non-free armhf Packages
Hit http://mirrordirector.raspbian.org jessie/rpi armhf Packages
Hit http://archive.raspberrypi.org jessie/ui armhf Packages
Hit http://ftp.debian.org jessie-backports/main Translation-en
Hit http://ftp.debian.org jessie-backports/main armhf Packages
Ign http://repo.mosquitto.org jessie/main Translation-en_GB
Ign http://ftp.debian.org jessie-backports/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/main Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/main Translation-en_GB
Ign http://archive.raspberrypi.org jessie/ui Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en_GB
Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en_GB
Fetched 166 kB in 12s (13.1 kB/s)
Reading package lists... Done
W: GPG error: http://ftp.debian.org jessie-backports InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 8B48AD6246925553 NO_PUBKEY 7638D0442B90D010
Building dependency tree
Reading state information... Done
Calculating upgrade... The following packages were automatically installed and are no longer required:
easy-rsa libpkcs11-helper1 opensc opensc-pkcs11
Use 'apt-get autoremove' to remove them.
Done
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
libgnutls28-dev is already the newest version.
libgnutlsxx28 is already the newest version.
libssl-dev is already the newest version.
libudev-dev is already the newest version.
make is already the newest version.
python3-dev is already the newest version.
python3-setuptools is already the newest version.
python3-sphinx is already the newest version.
Changing to homeassistant user
homeassistant@hassbian:/home/pi/scripts $ exit
exit
Activating virtualenv
Installing latest version of cython
Cache entry deserialization failed, entry ignored
Requirement already up-to-date: cython==0.24.1 in /srv/homeassistant/lib/python3.4/site-packages
Creating source directory
Cloning python-openzwave
fatal: destination path 'python-openzwave' already exists and is not an empty directory.
Cloning openzwave
error: pathspec 'python3' did not match any file(s) known to git.
Cloning into 'openzwave'...
remote: Counting objects: 25795, done.
remote: Compressing objects: 100% (35/35), done.
remote: Total 25795 (delta 28), reused 33 (delta 13), pack-reused 25745
Receiving objects: 100% (25795/25795), 101.96 MiB | 9.83 MiB/s, done.
Resolving deltas: 83% (14975/18035)
@penright All open-sourced projects suffer from lack of manpower and “got to put the kids to bed” issues. When you have an open-sourced project dependant on other open-sourced projects built with open sourced tools, things may not go as quickly or smoothly as one might want. I am sure the OpenZwave team will say that it will be ready when it is ready.
The alternative is to use a commercial Zwave hub like Wink, to connect your Zwave devices and use Home Assistant to tie things together.
I am sorry if I sounded unappreciative.
In fact, just the opposite.
I did not want to bug them if there was someone else here who knows the time line.
Just looked like they have it working in beta, and since Hass defaults to production, I was curious when they would move the beta to production.
