It might also be worth clearing the pip cache before reinstalling
so I blew away my virtualenv and started all over. Re-install home assistant, tried installing python_openzwave and now iâm getting this error:
invalid command name 'âflavor=ozwdev'
how is that even possible?
Edit: looks like there were some character issues copying from this forum. I tried the line from github with ozwdev and itâs building. Fingerâs crossed!"
How did it go?
works brilliantly. if was definitely an issue with my virtual environment where packages werenât getting uninstalled correctely. now itâs all set up and Iâm seeing the barrier class. Thank you for all your work and help!
Stop your homeassistant then, give this a try in your virtualenv:
pip3 uninstall python_openzwave
rm /srv/homeassistant/lib/python3.5/site-packages/libopenzwave.cpython-35m-arm-linux*.so
pip3 install python_openzwave --install-option="--flavor=ozwdev"
Once complete you can check it via the command: pyozw_check
It should tell you OpenZwave Version 1.5.xxxxx
Let us know how it goes.
You do not need the control panel as itâs built into HomeAssistant now.
Yes
Make sure to use âAdd Secure Nodeâ and that you have a network key setup in your config.
Something good or something bad?
You have to restart HA to have the rename(s) complete.
nope sorry
As far as I can tell it attempts to re-start contact with a device that has gone âdeadâ but is still really alive.
I think youâd use heal node on a âfailedâ node that appears fine.
Well you can copy your previous zwcfg_0xxxxx.xml over to the new file, Iâm not at home right now but it should be something like ozwcfg_0xxxxxx.xml I may have the filenames wrong so check the dates and make sure HomeAssistant isnât running before doing a copy, and make backups of each file.
Shouldnât my automations run off the names not the node numbers.
I get an error relating to pthread_setname_np being undeclared
Ok, so I had to patch the latest openzwave code as it doesnt compile on freebsd, but after that I have it working!
FreeBSD is a complex beast glad you got it working.
Yeah was a little tricky, but mostly just linking and include errors
I get the below error messages each time I have the developer installed and run home assistant:
File "src-lib/libopenzwave/libopenzwave.pyx", line 494, in libopenzwave.notif_callback
IndexError: list index out of range
2018-01-19 19:22:19 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=<state group.automation_view=off; assumed_state=False, hidden=True, view=True, friendly_name=Automation, entity_id=('group.automation',), order=10 @ 2018-01-19T19:22:14.234695-06:00>, entity_id=group.automation_view, new_state=<state group.automation_view=on; assumed_state=False, hidden=True, view=True, friendly_name=Automation, entity_id=('group.automation',), order=10 @ 2018-01-19T19:22:19.763420-06:00>>
UnboundLocalError: local variable 'n' referenced before assignment
Exception ignored in: 'libopenzwave.notif_callback'
2018-01-19 19:22:20 INFO (Dummy-23) [openzwave] Driver ready using library Static Controller version Z-Wave 3.95
2018-01-19 19:22:20 INFO (Dummy-23) [openzwave] home_id 0xe3fb5887, controller node id is 1
2018-01-19 19:22:20 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=zwave.aeotec_zw090_zstick_gen5_us, new_state=<state zwave.aeotec_zw090_zstick_gen5_us=unknown; manufacturer_name=Aeotec, new_entity_id=zwave.aeotec_zw090_zstick_gen5_us, old_entity_id=zwave.aeotec_zw090_zstick_gen5_us_1, node_id=1, friendly_name=Aeotec ZW090 Z-Stick Gen5 US, product_name=ZW090 Z-Stick Gen5 US, node_name=Aeotec ZW090 Z-Stick Gen5 US @ 2018-01-19T19:22:20.685218-06:00>>
2018-01-19 19:22:20 INFO (MainThread) [homeassistant.core] Bus:Handling <Event state_changed[L]: old_state=None, entity_id=zwave._, new_state=<state zwave._=unknown; manufacturer_name=, new_entity_id=zwave._, old_entity_id=zwave.__4, node_id=4, friendly_name= , product_name=, node_name= @ 2018-01-19T19:22:20.689474-06:00>>
terminate called after throwing an instance of 'OpenZWave::OZWException'
what(): Manager.cpp:2069 - InvalidValueIDError (101) Msg: Invalid ValueID passed to GetValueAsByte
Aborted (core dumped)```
What version of HomeAssistant?
I am running .61.0
Whatâs showing up in your OZW_Log.txt?
Below is the warning from the log:
2018-01-20 13:50:03.680 Warning, Exception: Manager.cpp:2069 - 101 - Invalid ValueID passed to GetValueAsByte
Sounds like you may need to reset the USB stick
Just interesting that it works perfectly fine when I reinstall the regular version of open zwave. So wonder why I would have to reset it.
