Link Daikin brp069c8x WiFi-module to HA
I have a Daikin air conditioning system that is controlled by the brp069c8x WiFi module. Since this module doesn’t offer local control and everything has to go through the cloud, additional steps are required to integrate it with Home Assistant to my understanding. Based on my research, I need to create an application in the Daikin Europe Developer Portal. When I try to enter the URI “https://my.home-assistant.io/redirect/oauth,” I keep getting the following error: “unable to create DCR from HTTP Invalid response: Error: invalid dcr http response.” Am I missing something?
I am very new to Home Assistant and have little experience with its configuration.
It would help if you stated which integration you are trying to use. For Daikin integration of modern devices there are two options available to you. Neither of which are native to Home Assistant.
Option 1 is a custom ESP device installed inside the unit.
Option 2 is to use HACS to install this custom component.
Option 2 is probably what you are using, but you have to follow the instructions exactly as stated.
I’m not helping at all, but I’m facing the same issue here.
It seems that the URI is not accepted.
I’m having the same issue when trying to create a new application in the Daikin developer portal. Has anybody been able to create a new application recently?
just use lowercase letter everywhere and put some text in the description. I managed to create one this way right now.
Cheers
What did I do wrong ?
Thanks for any help ! (Am very new to HASS)
Same error also for me. :weary:
I also tried:
And tried that too:
The issue might be [Issue]: Daikin Developer Portal unable to create application · Issue #279 · jwillemsen/daikin_onecta · GitHub
Maybe with this?
i hope this help someone,
ps im new in home assistant so i used some help from chatgpt, i have to say that it helped a lot to install hacs
did somebody find already a solution for the C8 ?
Does it work through the cloud ?
