LInking Home Assistant Installs
Here’s the scenario: Home Assistant instance running in Docker on a Ubuntu server in my basement. I have Hassio running on a Raspberry Pi 3+; located in a central location in the house. My Z-Wave USB stick is connected to the Pi. I’m only using the Pi install for Z-wave and Bluetooth. With it more centrally located I get more reliable coverage.
Is there an easier way to “link” the two HA instances? I currently do it through MQTT but its a bit clunky.
Thanks, Dan
