Linking two sonoff switches/entities
Hi all
I have two sonoff wall switches. One at the top of the stairs and one at the bottom. Is it possible to link these two together As it stands if I turn one on then walk upstairs and try to turn the light of it does not work as the switch downstairs has control and visa-versa.
So is it possible to link them all the time or group them so that activating one will always activate the other.
You’re probably going to need to provide more information to get a useful answer…
What model switches are you using?
Which communication protocol do they use?
Where are you in the world and how is this circuit wired?
What integration are you using to pull these devices into HA?
Hi.
Swithes are sonoff T1 nd T2 TX-EU
They are wifi. 2.4ghz
I have wired them all with Live and nutral wires.
Pulled with Ewelink.
Hope this helps
Hi.
Hope this helps
