Core: 2024.9.2
Frontend: 20240909.1
Running in a docker container.
When I attempt to install the Linn / OpenHome integration, I get the following error:
Any insight as to why?
Thanks for any help.
Core: 2024.9.2
Usually the integration is auto discovered, when a compatible device is online on the same LAN.
Do you have some and is it ON?
Thanks.
The device I have is on another vlan. I temporarily moved it to the same vlan and it was auto discovered. I was able to configure the Linn / OpenHome integration.
I appreciate the pointer.
