msly
December 6, 2022, 8:30pm
1
Linptech Presence Sensor
- Brand: Linptech
- Product Model: ES1ZB (MI)
- Product Color: White
- Product Size: 50.0x50.0x20.6mm
- Working Temperature: -10 ℃~40 ℃
- Operating Humidity: 0~95% RH, Non Condensin
- Executive Standard: GB4943.1-2022
- Power Consumption: 0.5W
- **Wireless Protocol: BLE Mesh**
- Radar Frequency: 24G
- Light Sensing Range: 0-10000lux
Note:Product Model: ES1ZB (MI) is BLE only and not Wifi or Zigbee!
This device can be added to MI home application
https://ultratrade.ru/products/datchik-prisytsviya-xiaomi-linptech-human-presence-sensor-es1-es1zb-/
https://shopee.ph/Linptech-Human-Body-Presence-Sensor-6m-Sensing-Distance-8-Gear-Interval-Adjustable-with-Illumination-Linkage-Smart-Home-Devices-i.72563893.19170147427
useful links
diy presence sensor use LD2410
HomeAssistant motion and presence sensor (use LD2410b and esp32c3 with esphome)
Diy HomeAssistant motion and presence sensor (use LD2410c and esp32c3 with esphome)
diy Low-latency presence sensor: mmWave + PIR using ESPHome
https://community.homey.app/t/created-a-mmwave-pir-presence-sensor-with-temp-and-humidity-and-luminance/76714/22
Tracking people with mmWave sensor LD2450https://www.hackster.io/craftiarenko/tracking-people-with-mmwave-sensor-ld2450-e5a9e9
msly
May 5, 2023, 1:40pm
2
领普人体存在传感器ES1ZB(MI)
Product Name: linptech Presence Sensor
Model Number: ES1ZB(MI)(China model)
Product Model Variant: ES1ZB(MI)
internal model :linp.sensor_occupy.hb01
Wireless protocol: ble (mijia)
Radar frequency: 24GHz-24.25GHz
Mi Home app : yes
https://home.miot-spec.com/spec/linp.sensor_occupy.hb01
how to use
https://github.com/custom-components/ble_monitor/issues/1108
or
https://github.com/AlexxIT/XiaomiGateway3/pull/868
useful links
https://rumihome.ru/ustrojstva/datchiki/datchiki-dvizheniya/linptech-es1
michel72
(Michel - IngeniousMakers.com)
December 3, 2023, 10:29am
3
Beware, I bought one of these, but there does not seem to be a ESP32-C3 inside. Just BLE.
No luck getting this to work with Home Assistant.
msly
December 4, 2023, 1:49pm
5
sorry, Linptech presence sensor ES1ZB (MI) is Wireless Protocol: BLE Mesh. not wifi
michel72
December 4, 2023, 2:01pm
6
Great, you are welcome to send me the wifi version free of charge
so any luck working with HA without Aquara hub? I have the same sensor and trying to find a solution which works with HA.
msly
December 15, 2023, 11:20am
8
Method 1. Mi Smart Home Hub2 + Xiaomi Gateway 3 for Home Assistant
Hardware:Mi Smart Home Hub2’s ble (only ble,not wifi and zigbee)
ha integration:Xiaomi Gateway 3 for Home Assistant
detail:
https://community.home-assistant.io/t/these-are-the-mijia-hub-gateway-devices-compatible-with-all-servers/491449/9?u=msly
michel72
December 15, 2023, 11:38am
9
No, no way of getting this into HA without the Xiaomi gateway, which is not something I would want.
Ideally you would want to add this as a BLE device directly either via the host, or using the esphome BLE-proxy.
If I would have not been so rudely misinformed by the topic starter, I would have ordered the zigbee or wifi version.
@msly , please correct your misleiding information it this topic.
nutrabaits
(Crolaser)
December 15, 2023, 12:21pm
10
Yes, i have also a zigbee model and this works great.
msly
December 19, 2023, 9:40pm
12
msly:
Can you tell me Product model?
nutrabaits
(Crolaser)
December 20, 2023, 10:09am
13
michel72
March 14, 2024, 10:28am
14
I’m reading stuff about specific BLE hardware that can be flashed with a zigbee variant of the firmware and that aces as a zigbee device. Does anyone know if there is something available for this ES1ZB (MI) (BLE version) as well?
Or…
Does anyone have this BLE device successfully working in Home Assistant and…how?
Ton2
(Ahpm Bammens)
April 21, 2024, 8:55pm
15
I have one of them succesfully connected to xiaomi gateway v3. But device doesn’t show up in homeassistant. What am i missing.
KVinS
July 12, 2024, 11:25pm
17
Did you manage to configure this?
Ton2
(Ahpm Bammens)
July 25, 2024, 7:51pm
18
Have two of them in homeassistant and they work fine. Find an old gateway3 with old version software. Have put it on cn service. Installed the linptech in mi home app and after that they show up in gateway3. (Installed via hacs)
