Linux 64 bit mqtt central control supports tmall homekit fool access
Link: https://pan.baidu.com/s/1qhH1C17GVYIhgurijW_ W9w extraction code: 8888
Debian 9 AMD64 bit test OK
  1. Support homekit access
  2. Esp8266 access
  3. Tmall Genie access
  4. Self link mqtt server
Homekit needs to be installed
apt-get install libavahi-compat-libdnssd-dev
Default user name admin password pass
/cmdapi/ setup.json Key MD5 stores the user password
Backup the configuration file first, and manually delete / cmdapi to restore the configuration file/ data.db Will recover
Homekit and mqtt can be run independently. Homekit can only run if all configuration files in the / cmdapi file exist
Pure green file, download the file to the specified folder
tar zxvf mqtt.tar.gz
./cmd start
Start command
