Linux Mint, Mosquitto, Docker, Smartthings Issues (RESOLVED)
I seem to be having some issues getting my Home-Assistant setup and my Smartthings Hub to communicate with one another. I used this tutorial to set up Mosquitto/Docker and the Virtual Environment tutorial to set up Home Assistant. I made a few alterations from the YouTube setup, which I’ll post later.
After running
mosquitto_sub -d -u <username> -P <password>-t dev/test
mosquitto_pub -d -u <username> -P <password> -t dev/test -m "Hello world"
mosquitto_sub -u <username> -P <password>-v -t '#'
I verified that it seems to be working on the device. When I hit a switch with the following config:
switch:
  - platform: mqtt
    name: "Laundry Room Light"
    state_topic: "smartthings/Laundry Room Light/switch"
    command_topic: "smartthings/Laundry Room Light/switch"
    payload_on: "on"
    payload_off: "off"
    retain: true
the terminal spit back smartthings/Laundry Room Light/switch off (or on).
Here is my mqtt config in configuration.yaml:
mqtt:
  broker: localhost
  username: myusrname
  password: mypass
my mosquitto.conf file:
# Place your local configuration in /etc/mosquitto/conf.d/
# A full description of the configuration file is at
# /usr/share/doc/mosquitto/examples/mosquitto.conf.example
pid_file /var/run/mosquitto.pid
persistence true
persistence_location /var/lib/mosquitto/
log_dest file /var/log/mosquitto/mosquitto.log
include_dir /etc/mosquitto/conf.d
allow_anonymous true
password_file /etc/mosquitto/pwfile
and this is the docker/mqtt-bridge config.yml file:
mqtt:
    # Specify your MQTT Broker's hostname or IP address here
    host: 192.168.1.148
    # Preface for the topics $PREFACE/$DEVICE_NAME/$PROPERTY
    preface: smartthings
    # Suffix for the state topics $PREFACE/$DEVICE_NAME/$PROPERTY/$STATE_SUFFIX
    # state_suffix: state
    # Suffix for the command topics $PREFACE/$DEVICE_NAME/$PROPERTY/$COMMAND_SUFFIX
    # command_suffix: cmd
    # Other optional settings from https://www.npmjs.com/package/mqtt#mqttclientstreambuilder-options
      username: myusrname
      password: mypassword
# Port number to listen on
port: 8080
Any ideas on what I’m doing wrong? This is my second try from scratch and I got further this time, but still can’t get it running properly…
Thanks!
