I run Home Assistant on Raspberry Pi 3 for about a year now. It is getting slow. I created a new install on another Raspberry Pi 3, but it is still slow.
I remembered that I have a small PC in my closet and I believe I should be able to use it. I think about installing Ubuntu Server 16.04.4 LTS.
When you use this installation method, some add-ons will not be available, and the documentation might not work for your installation.
It looks like that I’d better install HA in Python Virtual Env on Linux system? I do not like an idea that some add-ons will not be available to me on Hass.io.
Thank you.
On the Docker page, there is a section that is talking about Docker Compose. I have a few question, can you answer?
It says to create file docker-compose.yml. Should it be docker-compose.yaml?
Where should I place it to?
Also, does everything else work as with other installations? For example, it is not starting automatically. Should I do all steps that are in Autostart section on HA website?
If you want to do a basic install on the server (no docker, hassio, etc), you can try these instructions: Home Assistant Fresh on Ubuntu 16.04 server
With the latest 3.5.4 python requirement, you may need to install a newer version of python using miniconda or a different apt repo (conda install). Works fine, no limitations as far as I can see. I’ve been running HA this way for awhile and never had any issues.
Sorry, another question. I installed docker and specified my config directory. It added files in that config directory, but when I edit .yaml files, the system does not take it. Even after reboot. I see the change in my file, but no change on the page.
For example, I removed introduction in configuration.yaml file, but the welcome card is still showing up. I also added something, but it does not show up.
What can it be? Is there another place for all those config files, but in this case, why did it place it in that config directory that I specified?
@TD22057, thank you for your reply. Looks like the installation that you show me is Python Virtual Env. I have done it a few times. I decided to try something new. If it does not work for me, I will reformat my device and start from scretch.
I am sure that I did not setup it in virtual env this time. I installed Ubuntu and run
docker run -d --name=“home-assistant” -v /home/homeassistant/home-assistant:/config -v /etc/localtime:/etc/localtime:ro --net=host homeassistant/home-assistant
After that, I configured auto start and nothing else.
Also, I tried command that you suggested and have this:
homeassistant@HomeAssistant:~$ docker ps -a
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
d63d696df95b homeassistant/home-assistant "python -m homeassis…" 11 minutes ago Up 11 minutes home-assistant-homeassistant
53cfc5394229 homeassistant/home-assistant "python -m homeassis…" About an hour ago Exited (0) About an hour ago home-assistant
Where is that second installation and why do I have it? What should I do to fix it?
I found that I have files in config directory that I specified: /home/homeassistant/home-assistant and also, I have it in /home/homeassistant/.homeassistant
The same files are placed in two different places. Why is that Can I remove one of them? How to remove it from Docker?
There is no “auto start” configuration that needs to be done for docker.
Please understand these aren’t “installations”. These are just running images. You ran the command twice. That’s why you have another instance.
Spend some time to understand what you’re doing.
You never told your container to restart. By running the command again, you fired up another running container. You can kill them by running docker kill <idofcontainer>
Please look into docker compose and set up your file
If you scroll down on that page, there is a section about Docker Compose. It says to create docker-compose.yml file (why .yml and not .yaml) and it does not say where should I place that file.
