Trying to enable Cloudflare, but getting this error when attempting to update records.
list index out of range
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 134, in handle_call_service
connection.context(msg),
File "/usr/src/homeassistant/homeassistant/core.py", line 1226, in async_call
await asyncio.shield(self._execute_service(handler, service_call))
File "/usr/src/homeassistant/homeassistant/core.py", line 1253, in _execute_service
await self._hass.async_add_executor_job(handler.func, service_call)
File "/usr/src/homeassistant/homeassistant/components/cloudflare/__init__.py", line 50, in update_records_service
_update_cloudflare(cfupdate, email, key, zone, records)
File "/usr/src/homeassistant/homeassistant/components/cloudflare/__init__.py", line 67, in _update_cloudflare
update_records = cfupdate.get_recordInfo(headers, zoneid, zone, records)
File "/usr/local/lib/python3.7/site-packages/pycfdns/__init__.py", line 56, in get_recordInfo
recordInfoResponse = recordInfoRequest.json()['result'][0]
IndexError: list index out of range
2020-02-05 08:00:11 DEBUG (SyncWorker_11) [homeassistant.components.cloudflare] Starting update for zone zozobrado.com
2020-02-05 08:00:11 DEBUG (SyncWorker_11) [homeassistant.components.cloudflare] Header data defined as: {'X-Auth-Email': '{email}', 'X-Auth-Key': '{apikey}', 'Content-Type': 'application/json'}
2020-02-05 08:00:11 DEBUG (SyncWorker_11) [homeassistant.components.cloudflare] Zone ID is set to: {the correct Zone ID}
2020-02-05 08:00:12 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.139859816021136] list index out of range
It successfully discovered my zone key. But then failed right after that.
I removed all but one, new, entry. And it’s still failing.
Is there anyway to get an output of the return data? That could provide some clues. “Debug” isn’t as verbose as I’d like (I’d like to see the HTTP request URL and Headers, and Raw Response body).
So if you take your zoneID for each record that it returns and fill in the <record.zone> and use your header, you should be able to see what that returns with curl.
Ah ha! That’s the clue! The component does not compensate for new records.
That’s where it was failing. I had a list, to debug how it “looks” in CF after HA runs. I thought it would create new entities for those not found. My list consisted of two manually added ones, and a new entry.
I have removed the “new” entry (only need the two right now), and it now works!
Thanks, @jocnnor. With your help, I was able to track down where and why it was failing.
