Looking for a little help here and know it will be simple for many but not for me as I can do most things with HA but struggle a little with templating.
How do I create a list (preferably with line breaks) of all input Booleans that have the label X and are in the ON state?
Line 1 gets all the input boolean state objects. It’s equivalent to states.input_boolean but I prefer the bracket notation which is almost always either equivalent or better. (Accessing state objects)
Line 2 filters that list to those elements that have the label you want. (Docs for selectattr, in, and label_entities)
Line 3 then filters again to only select state objects with a state of on.
Line 4 then returns just the entity IDs of the state objects. (map)
Line 5 turns this “generator” into a list (in effect, it “runs” the set of statements and gets the output). (more on generators only if interested)
Line 6 then joins the list items together with a line break character. You might want to use <br> instead of \n depending on your application. (join)
Remember that if you’re using this as a state for a template sensor, states are limited to 255 characters.
Example on my system (using Tablet label, binary sensors and off state so that there’s more than one):
