Lists not found error in custom intents
I tried to write custom intents in my configuration.yaml
this works fine:
conversation:
  intents:
    Test:
      - "test"
intent_script:
  Test:
    speech:
      text: "Test"
Then I tried to use lists as in this example: Assist - Custom Sentences - Home Assistant
conversation:
  intents:
    Test:
      - "test"
    Weather:
      - "[What is the] weather like in {weather_city}?"
lists:
  weather_city:
    values:
      - in: "City 1"
        out: "sensor.openweathermap_condition"
      - in: "City 2"
        out: "sensor.openweathermap_condition_2"
intent_script:
  Test:
    speech:
      text: "test"
  Weather:
    speech:
      text: "The Weather is {weather_city}"
But when I try to validate my configuration.yaml I get this Error “Integration error: lists - Integration ‘lists’ not found.” How can I fix this?
This probably is an indents mistake (not intents :wink: )
The lists: entry has to be at the same indentation level as the intents: entry.
Thanks for your reply!
So, I tried this:
conversation:
  intents:
    Test:
      - "test"
    Weather:
  lists:
    weather_city:
      values:
        - in: "City 1"
        - in: "City 2"
intent_script:
  Test:
    speech:
      text: "test"
  Weather:
    speech:
But now I just get a different error: Invalid config for [conversation]: [lists] is an invalid option for [conversation]. Check: conversation->conversation->lists.
