Little guide: make map-card icons to semi-transparent/ opaque with card-mod
I had always a sore eye when looking map-card with zone-entity icons covering people faces when person was at home, work etc. I did not find a one stop answer for making map-card icons semi transparent/ opaque, so I hope this helps someone looking to do same thing.
You need:
after adding the map card to lovelace, insert following code in the card code editor:
card_mod:
  style: |
    ha-card {
      --card-mod-icon-color: rgba(0,0,0,0.3);
The rgba values first 3 digits are rgb-colours and the last 4th digit is the opacity.
For example you could have map-card code like this:
type: map
entities:
  - zone.home
  - person.you
  - person.me
card_mod:
  style: |
    ha-card {
Hope this help, happy Home Assistant tinkering!
I’m wondering now that I put this in “Share your projects”-section, should this be in the “community guide”-section? This is so small guide though.
