since my last power failure i have the problem, that my knx devices become unavailable every x (3-6) minutes in their states. Restarting HA does not solve the problem.
I had this problem one month ago after update process to HA Version 11.2. I used my backup to go back to earlier version and it was gone. Now it is here again.
How can i check why this problem occurs. Mainly i only recognized it by my knx integration where i want to switch on all lights or turn on all covers. Normally the covers will close at the same time. When i come into a weaky phase than the covers will turn cover after cover. It seems that the knx telegrams are “slower”.
Hi ! This usually means that the connection to the Knx IP interface gets disconnected. Originating either from HA, but most commonly from the device itself - see logs.
Is HA the only thing using that device?
