Hello everyone,
I have a short question. I have a Z-Wave Network with 40 devices (Fibaro Walli Roller Shutter, Aeontec devices and so on). Now I want to install Fibaro Walli Switches and Fibaro Walli Dimmer for my lights:
https://manual.zwave.eu/backend/make.php?lang=en&sku=FIBEFGWDSEU-221
https://manual.zwave.eu/backend/make.php?lang=en&sku=FIBEFGWDEU-111&cert=ZC10-19046426&type=mini
On the other site I also want to use some Zigbee devcies. I have 14 Hue lamps (at the moment connected to my hue brigde) but for testing a connected 3 lamps to my conbee 2. My plan is to connect all hue lamps to the conbee 2. I also want to use some aqara devices in my house and here is were my question begins
We have a lot of concrete walls and the conbee 2 is not able to communicate with the aqara devices in the next room or upstairs. So I connected the Hue lamps to the conbee 2 and the mesh network was able to connect to the aqara devices, but when the switch for the lamps is turned off, the connection is broken again. My first plan was to install Fibaro switches because I thought that when I press the button on the switch, the power is not interrupted and the Hue lamps continue to work as repeaters. Unfortunately, the Fibaro switches also turn off the power. Now the question is, is there a better solution than the Fibaro switches, or can I set the Fibaro switches so that when I press the switch that only a scene is triggered, which dims the lamps in the room to 0 percent.
Sorry for the long explanation…but I hope this makes the problem understandable.
In short, I want the Hue lamps to always work as repeaters even when the switch in the room is pressed. The option to completely remove the switches and make them “blind” is out of the question for me…
Thanks for your help
