LbDab
(Lb Dab)
February 22, 2019, 9:29am
1
Hi I made live network diagram and wanted to share
For this used InfluxDB + Grafana + Mermaid plugin
In Home Assistant make ping binary sensor for every device
In Grafana Addon setting add “jdbranham-diagram-panel” to plugins like this:
"plugins": [
"jdbranham-diagram-panel"
In Grafana add “Diagram” panel
In panel settings>metrics add your ping binary sensors like this:
In panel settings>diagram write code for your diagram, here is example of mine:
graph TD
linkStyle default interpolate basis
wan1[<center>DSL 100/10 Mb<br><br><a href='http://10.100.102.1' target='_blank'>10.100.102.1</a></center>]---router{<center>EdgeRouter-X<br><br><a href='https://10.20.30.1' target='_blank'>10.20.30.1</a></center>}
ip((<center><br>IP<br><br></center>))-.-router
dns((<center><br>DNS<br><br></center>))-.-router
wan2[<center>LTE 50/20 Mb<br><br><a href='http://192.168.1.1' target='_blank'>192.168.1.1</a></center>]---router
router---|100Mb|ap[<center>RT-AC1200<br><br><a href='http://10.20.30.3' target='_blank'>10.20.30.3</a></center>]
router---|1Gb|pc(<center>PC<br><br>10.20.30.190</center>)
router---|1Gb|switch[<center>TL-SG105E<br><br><a href='http://10.20.30.2' target='_blank'>10.20.30.2</a></center>]
subgraph
ap-.-cam1(<center>Camera<br><br><a href='http://10.20.30.171' target='_blank'>10.20.30.171</a></center>)
ap-.-cam2(<center>Camera<br><br><a href='http://10.20.30.172/cgi-bin/status' target='_blank'>10.20.30.172</a></center>)
ap-.-phone(<center>Phone<br><br>10.20.30.191</center>)
ap-.-ir(<center>IR<br><br>10.20.30.180</center>)
end
subgraph
switch---|100Mb|pi1(<center>RPi 3B<br><br><a href='https://10.20.30.150:8123' target='_blank'>10.20.30.150</a></center>)
switch---|1Gb|pi2(<center>RPi 3B+<br><br><a href='http://10.20.30.151' target='_blank'>10.20.30.151</a></center>)
switch---|100Mb|nvr(<center>NVR<br><br><a href='http://10.20.30.170' target='_blank'>10.20.30.170</a></center>)
switch---|1Gb|laptop(<center>Laptop<br><br>10.20.30.192</center>)
end
Diagram live editor and documentation:
https://mermaidjs.github.io/mermaid-live-editor
UPDATE:
Added IP as clickable links
Rounded lines, hide indicator, plugin link
thibmaek
(Thibault Maekelbergh)
March 8, 2019, 10:13am
3
@LbDab How does this actually live update? Mine seem to be online even when binary_sensor.ping returns false. In this case the RasPlex host is offline in HA.
graph TD
router{<center>Telenet Modem<br><br><a href='https://10.20.30.1' target='_blank'>10.20.30.1</a></center>}
subgraph Raspberry Pi's
panorama(<center>Panorama<br><br>192.168.1.142</center>)
rasplex(<center>RasPlex<br><br>192.168.1.160</center>)
end
LbDab
(Lb Dab)
March 8, 2019, 11:04am
4
When color is light green meaning it is not reading state
seems I forgot to mention this part setting threshold options:
thibmaek
March 8, 2019, 11:30am
5
Still not seeing anything with that config:
Do the graph elements need the same name as the entity_id?
LbDab
(Lb Dab)
March 8, 2019, 11:35am
6
Yes, I see yours called “panorama_host” try this:
panorama_host(<center>Panorama<br><br>192.168.1.142</center>)
thibmaek
March 8, 2019, 11:48am
7
Now it’s working!
I had to use the exact same name in the alias field:
algenty
(Arnaud Genty)
April 30, 2019, 12:01am
8
Since few month, i’m writing a plugin to draw complexe diagram instead mermaid
Do you know Flowcharting plugin ?
Flowcharting, plugin for Grafana to create complexe visio's draws style like technical architectures, floorplan, diagrams, hierarchical schema based on draw.io - algenty/grafana-flowcharting
Best regards
Arnaud
LbDab
(Lb Dab)
April 30, 2019, 1:14pm
9
Thanks it looks great, will try it later
ben
(Ben)
July 4, 2019, 7:39pm
10
This is very cool. I don’t have experience with any of those plugins but I’ll have to try them out.
Do you think it’d be possible to add Z-wave or other device status to the diagram?
LbDab
(Lb Dab)
July 5, 2019, 1:40am
11
It is possible to add anything to diagram but to see its status there should be sensor for that
It can also be a template sensor if there is no ready one
DubSmith
(Will)
November 25, 2020, 6:54pm
12
This is awesome, thank you! Couple questions, how did you hide the indicator? I’d like to remove the “1” when a device is up and just use the color threshold.
Also the hyperlinks no longer work, I believe it was a security change in Mermaid. It looks like you can disable it, but I’m not sure where to add this config change?
mermaidAPI.initialize({
securityLevel: ‘loose’
