don’t use “_snapshot” use the real camera.
(and fix my typo… i transcripted incorrectly w/o a german keyboard )
your rtsp stream url should be fine, but you could also use:
{{ state_attr(‘sensor.engangstuer_info’, ‘stream_Source’) }}
instead (note that i used the sensor.*_info entity
btw, you said you were struggling for hours on this. one hint is that when you have an error in a template, use the developer-tools->templates feature to figure it out.
if you took that first url and put it in the template evaluator, it would have barfed at you. then you can fix it up. i don’t know exactly why the entity attribute specifies the state in that way. arguably it should specify it as i have above. … maybe someone else more knowledgable than me about that could answer that.
in the camera.eingagstur, replace that with the correct name of your camera. for me, it was the same name but without the _snapshot, so i was guessing that was the same for you.
you did the right thing by going to dev tools… you sould see that it gave you an url that wasn’t valid… i presume you know where to find the right camera identity id?
if you look in dev tools->states you should be able to find your camera and one of the attributes will be entity_picture. e.g. it’ll start with /api/camera_proxy/camera…
When I look through the states in the dev tools I have no camera without the “_snapshot”. That is the only entity with “camera” in its name. Is that the root of my problems?
that’s a bit strange.
when you go to your ring integration, you should see a bunch of entities. click on all the entities. there should be one of them which is a camera. right??
assuming so, click on that. in the popup, hit the gear icon in the upper right.
what’s the entity id that comes up in that subsequent screen?
(I also renamed the device and all its entities from “Eingangstür” to “Eingangstur” in case the umlaut was making problems, but I noticed that the URL I got from the attributes of sensor.eingangstur_info still contains the “ü”. I hope that’s not causing problems.)
there looks like something wacky with your ring integration because it should be providing a camera. however we might be able to work around it because mqtt may have what it needs.
ok, can you try this… for the rtsp stream do (note that we’re going to use the ‘sensor…_info’ entity): {{ state_attr(‘sensor.engangstuer_info’, ‘stream_Source’) }}
for the image url let’s go ahead and use the snapshot entity. it may be perpetually out of date but for now let’s just get it working:
adding some info here for others who may hit this. ina and i continued in chat…
issues were a) bad ring-mqtt token (not sure how this happened) b) snapshot image wasn’t generating. c) the wrong urls
solution
force reauth
use a random other image (wikimedia url) for the still image to create the generic camera
use the urls above.
fix up still image to mqtt image (we ended up still getting a 500 error from the mqtt still image url. i think there is something corrupt in his mqtt integration)
Has anyone figured out how to show a live view of the ring door bell on the lovelace only when the doorbell is pressed? I rely on the notification to my phone and having the rtsp stream going all the time will prevent me from getting a notification. I would like to just be able to see who is at my door on the stream
I am stuck…could anyone point me in the right direction?
I have the RING - MQTT add on installed and running. I was able to authenticate using user name and password for my ring account. (I do not have the RING integration running)
I see all four (4) of my ring cameras listed and each have many entities listed in my HASS device/entities page.
The Generic Camera integration does not seem to be accepting my inputs.
Thanks after reading 50 posts where people just said “it’s in the add on”, someone finally gave the right answer. The unintuitiveness of this platform is astonishing. Since a million people want this info, why not put it in the device info by default?
This add-on is wonderful. It is not for the newest of people that is for sure. Here are some of the issues I faced and hopefully they can help others:
I was able to add the repository in add-on and install the addon
I already had an MQTT integration but there are many videos even how to do this.
I use “duckdns” for my HASS setup but remember the MQTT server is the local IP address of your HASS install to place in the MQTT_url which is found in ‘configuration’ at the top of the add-on.
In this example, “user” is my mqtt username followed by “:” then mqtt password and the IP address of your Home Assistant followed by “:” and port “1883” I set up a specific mqtt user in the step above setting up a mqtt integration
The default configuration "mqtt://auto_username:auto_password@auto_hostname:1883" did not work for me.
Don’t forget to click “Open Web UI” in the main ring-MQTT add-on screen. (next to ‘uninstall’) this will log you into your RING account using a 2FA. (this was my hang up because I’m an idiot evidently I didn’t know this step had to be done)
Now you need to add to a generic camera device in the integration menu, to see the streams.
Open up the add-on, I clicked ‘restart’ and then opened up the ‘logs’ tab at the top (next to configuration).
I did a simple ctrl+F to search the logs for ‘rtsp’ and in those 2 lines I had information to fill the fields: ‘Still image URL (e.g. http://...)’ and ‘Stream source URL (e.g. rtsp://...)’
This was a pain but worth it and I hope if you do have issues remember to restart the add-on by clicking ‘restart’ or just restarting home assistant
