I assumed the switch.afstandbediening_2_4
both numbers are the first the node_ID assigned by the gateway, and the second number the child_ID that we assigned in the sketch, in this case, 1
my node_ID is 19 and the sketch name is livolo, so the string will be switch.livolo_19_1
so
[schakelaars]
module = RFSwitch
class = RFSwitch
switch01 = switch.livolo_19_1
total_switches = 12
switchcode1 = cade01A5504B16
switchcode2 = jant01A5504B56
switchcode3 = corr01A5504B8
switchcode4 = tele01A7849B19
switchcode5 = sanc01A7849B8
switchcode6 = vara01A7849B56
switchcode7 = cort01A17035B16
switchcode8 = sala01A17035B56
switchcode9 = sofa01A17035B8
switchcode10 = alla01A5504B42
switchcode11 = allb01A7849B42
switchcode12 = allc01A17035B42
but there is no communication yet…
is there a way to verify the daemon app is running?
the serial gateway from the arduino shows:
��E�q�t�!G֒�����Aá<�{�ey�HB�G��)0VStarting sensor (RNNNA-, 2.0.0)
TSM:INIT
TSM:RADIO:OK
TSP:ASSIGNID:OK (ID=19)
TSM:FPAR
TSP:MSG:SEND 19-19-255-255 s=255,c=3,t=7,pt=0,l=0,sg=0,ft=0,st=bc:
TSP:MSG:READ 0-0-19 s=255,c=3,t=8,pt=1,l=1,sg=0:0
TSP:MSG:FPAR RES (ID=0, dist=0)
TSP:MSG:PAR OK (ID=0, dist=1)
TSM:FPAR:OK
TSM:ID
TSM:CHKID:OK (ID=19)
TSM:UPL
TSP:PING:SEND (dest=0)
TSP:MSG:SEND 19-19-0-0 s=255,c=3,t=24,pt=1,l=1,sg=0,ft=0,st=ok:1
TSP:MSG:READ 0-0-19 s=255,c=3,t=25,pt=1,l=1,sg=0:1
TSP:MSG:PONG RECV (hops=1)
TSP:CHKUPL:OK
TSM:UPL:OK
TSM:READY
TSP:MSG:SEND 19-19-0-0 s=255,c=3,t=15,pt=6,l=2,sg=0,ft=0,st=ok:0100
TSP:MSG:SEND 19-19-0-0 s=255,c=0,t=17,pt=0,l=5,sg=0,ft=0,st=ok:2.0.0
TSP:MSG:SEND 19-19-0-0 s=255,c=3,t=6,pt=1,l=1,sg=0,ft=0,st=ok:0
TSP:MSG:READ 0-0-19 s=255,c=3,t=6,pt=0,l=1,sg=0:M
TSP:MSG:SEND 19-19-0-0 s=255,c=3,t=11,pt=0,l=6,sg=0,ft=0,st=ok:Livolo
TSP:MSG:SEND 19-19-0-0 s=255,c=3,t=12,pt=0,l=3,sg=0,ft=0,st=ok:1.0
TSP:MSG:SEND 19-19-0-0 s=1,c=0,t=20,pt=0,l=0,sg=0,ft=0,st=ok:
Request registration…
TSP:MSG:SEND 19-19-0-0 s=255,c=3,t=26,pt=1,l=1,sg=0,ft=0,st=ok:2
TSP:MSG:READ 0-0-19 s=255,c=3,t=27,pt=1,l=1,sg=0:1
Node registration=1
Init complete, id=19, parent=0, distance=1, registration=1
Sending initial value
TSP:MSG:SEND 19-19-0-0 s=1,c=1,t=2,pt=2,l=2,sg=0,ft=0,st=ok:0
Requesting initial value from controller
TSP:MSG:SEND 19-19-0-0 s=1,c=2,t=2,pt=0,l=0,sg=0,ft=0,st=ok:
TSP:MSG:READ 0-0-19 s=1,c=1,t=2,pt=0,l=1,sg=0:0
