Livolo zigbee switch / conbee / zigbee
Hello , i am just starting with this hassio , i’ve got hassio Running , bought myself a conbee , got it installed and running , just cant make the conbee find my livolo zigbee switches or the gateway. I have got three of these switches and the gateway for it , but it would be nice to be able to switch them from the dashboard in hassio.
Anyone made this working allready?
How do you mean with finding the gateway? You only have one gateway for a single network and a gateway can’t usually act as a repeater in a system it is not managing itself.
As i told before , i am new at this… I have the zigbee livolo switches and the livolo gateway for it… When i started the webui for the conbee in hassio , it was just searching for lamps… Couldn’t get any furthee… Than on the internet i found a link in a forum handling this problem , when i opend that it started the application for conbee but it was searching for gateway… Without result… So that’s why i wrote that down…
Ok so your lights are paired with your other gateway right now?
Its three switchesvi have and they are paired with the standard livolo gateway.
These are the switches
So you would need to remove them from the gateway and reset them before being able to pair them with deconz, if they are supported which it doesn’t seems like.
https://github.com/dresden-elektronik/deconz-rest-plugin/issues/997
But you can do a device request if that is not the case.
Ok. I will look into that. Thx
Hi Fifke, did you manage to connect livolo ZigBee switch to hassio by deconz?
No didnt work…
I am trying to get a workaround working for now , but also no succes yet… As the livolo switches are compatible with Alexa i would like to trigger them true routines and tts… Still working on that taugh…
Got that running now. I can control the switches now true a script and the Alexa app
What about creating a component for integrating the switches through Livolo’s cloud?
There is already an implementation for HomeBridge.
Well that would be great! I havent got any programming skills so every help is welcome! Now i got my switches controled true Alexa media , but no feedback on states they are in… I am allready happy i can control them but its not quite the way i would like it to be.
Does anyone know why in conf.yaml when I push start removes some lines like experimental Livolo true ?
Does anyone know why in conf.yaml when I click start removes the lines experimental Livolo true ?
