Buongiorno, finalmente ho ricevuto i dati richiesti a Livoltek, avviando l’applicazione vedo che ci sono molte meno entità rispetto a quelle visualizzate nella foto postata il 18 marzo, ad esempio non riesco a visualizzare il livello della batteria, come posso risolvere? grazie
TL;DR Livoltek added Security ID UI to the portal (similar to “Generate Token”).
- Contants at site not responding
- I found them on LinkedIn and asked for help
- They forwarded me from LinkedIn to the WhatsApp
- After a few weeks of discussions (in the end, they added an engineer from the R&D team), they released a new UI
- Victory
Hi!
Im trying to add livoltek integration using livoltek portal token security id and key but I get Invalid Athentication.
what could be wrong?
thanks
Had the same problem, the key displayed by the web page contained the “\” character which is interpreted as an escape character and not displayed. I solved it by copying the key with the copy function into the “operate” cell.
I have succesfully setup the integration of the hass-livotek
FYI, the process to follow to get security ID, token and API Key is the following:
1.Go to LIVOLTEK Monitoring, log in
2.Top right, go to your profile and you will see the panel and tabs for generate token and security ID
3.Go to generate token tab, click the +add button and setup an effective date in the future, the password requested is the one of your Livoltek account
4.Go to Security Id tab and click the +add button to generate a security Id and a Key
5.Finally use the 3 values above to fill the HA integration panel
!!!Important!!! After copying those value in HA I got an authentification error, I have contacted support (which was very responsive and helpfull) and they told me there is a need to add “\r\n” at the end of the KEY. so the final format of your key is what you copy from the dashboard and the string, like KEY\r\n
Interesting post for the future! I will have a Livoltek in some weeks
With \r\n in the api key i got “unknown error”, without “Invalid authentication”
LoL
Any updates on this?
This week I get the chance to test a livoltek battery. It would be nice to be able to fully utilize this with emhass.
Do you also know if there is a local API to use modbus over IP or something?
Any luck making this work, I was able to pass the Key, token and all, but after that I am ask to add the site, which I am also able to give, however no device nor entities are visible, just “1 Entry”
Hi everybody!
@adamlonsdale in the first place, thank you very much for making hass-livoltek integration! It arrived just in time for me.
I’d been a happy user of hass-livoltek for past few months but it got stuck after updating HA to 2024.12.3 (from 11.3). The integration failed to load. It also failed to be deleted via UI. So I manually removed files and tried to add the integration from scratch but I got the following error:
“Config flow could not be loaded: 500 Internal Server Error Server got itself in trouble”.
Searched the forum - it’s a common issue for many integrations after moving to 2024.12, usually resolved by changes done by authors.
@adamlonsdale, could you please look into that?
Piotr
Ok, I was able to resurrect livoltek integration after upgrade to 2024.12.5
BTW, I’m also looking forward to being able to change Work Mode (SelfUse, Selling First etc.) from HA.
Best wishes for New Year!
Is this Integration still working? Any update on this?
I tried today but the authentication doesn’t work…
Do you have any suggestion to how integrate the inverter with home Assistant?
Is still working on your device?
I set this up yesterday following the instructions from @pascalmoise above - it works great! (well, it was working until mid-morning this morning when we seem be getting 500 errors from the API itself).
When you’re generating the keys in Livoltek Monitoring, make sure you’ve set a date in the future for the Token, and also make sure to put \r\n at the end of your KEY when you copy it into Home Assistant.
If you’re registered on the Europe/Middle East/Africa Livoltek server, make sure to tick the ‘Use EMEA server’ box when setting up the integration.
Is it possible to make somehow use of the “Local Mode”? Meaning to connect to the inverter wifi/bluetooth and use the data directly, without needing to use the API server(s).
I’ve asked the Livoltek team about this, but they didn’t respond yet(two weeks have passed). On mobile, if I use the Local Mode and I’m connected directly to the battery/inverter WiFI, the data is sent in real time, without that 5 minutes (or more) delay.
