Hi all,
I’m using LK IHC switches throughout my house to control e.g. my Hue lights. I’m also using a few relays and reed switches.
I am experiencing that all my LK wallswitches (binary_sensor) become unresponsive, often once or twice a day, without anything showing up in my logfiles. When this happens I can still control the ‘outputs’, for example open my garage, which shows the connection is not really lost.
But the reed switch (also binary_sensor), that tells if it’s open or not does not change state. Neither do they say ‘Unavailable’ - they simply just keep their last state from before “it” happened Restart hass.io solves it until next time
My colleague has the exact same problem on his hass.io instance.
I know it is pretty much impossible to help when I cannot show any errors from logs, but I’m hoping one more skilled than me can look into the code (probably specifically for binary_sensor) and see if there is something that sticks out.
I’ve added this to my logger without luck: homeassistant.components.ihc: debug
My config:
url: http://192.168.100.3
username: admin
password: xxxxxxxxx
auto_setup: True
info: True
binary_sensor:
#Stue#
#1 Ved dør til køkken#
- id: 19804
- id: 20060
- id: 20316
- id: 20572
etc.
Thanks in advance!
EDIT: github issue: https://github.com/home-assistant/home-assistant/issues/26850
