LLM sees scripts but not actually calling them
I’ve recently configured a fully local LLM on my desktop with 12GB of VRAM. I have tried running 7B and 14B models and they both run pretty well. I have set up some routing via LiteLLM. I wanted to play with these in Home Assistant so I installed the Local OpenAI LLM integration (via HACS) and connected my LiteLLM endpoints. Everything in basic testing seems to work well through Voice Assist with this LLM. Where I am hitting a bump is getting the LLM to actually call any scripts. It seems to be able to interact with the home just fine, and it recognizes that the scripts exist, but it won’t actually run the script…
I am specifically trying to call the LLM script for Music Assistant that’s configured with a Blueprint. It just wants to keep outputting the JSON it would use to call the script.
Anyone have any ideas of what could be happening here? I’ve confirmed I have the ‘tools’ calling capability enabled, and the script is exposed.
Here is a recent conversation I tried:
Me:
play music by taylor swift in the office
Assist:
To play music by Taylor Swift in the office, I’ll use the llm_script_for_music_assistant_voice_requests function.
{ “name”: “llm_script_for_music_assistant_voice_requests”, “arguments”: { “media_type”: “artist”, “artist”: “Taylor Swift”, “album”: “”, “media_id”: “Taylor Swift”, “media_description”: “music by Taylor Swift”, “area”: [“Office”], “media_player”: , “shuffle”: false } }
Me:
Yes, now actually do the tool call…
Assist:
I’m sorry for any confusion, but as an AI assistant, I don’t have the capability to directly execute tool calls or interact with your home automation system. I can only provide the instructions on how to do it.
To play music by Taylor Swift in the office, you would need to use the llm_script_for_music_assistant_voice_requests function with the provided arguments. Here is the JSON object again:
  "name": "llm_script_for_music_assistant_voice_requests",
  "arguments": {
    "media_type": "artist",
    "artist": "Taylor Swift",
    "album": "",
    "media_id": "Taylor Swift",
    "media_description": "music by Taylor Swift",
    "area": ["Office"],
    "media_player": [],
    "shuffle": false
You can copy this JSON and use it in your Home Assistant environment to execute the command.
Turns out it really was just a problem with the model I was using… I was trying to reuse some qwen2.5-coder models I had been playing around with earlier. I had read they should be fine at tool calling, but that’s obviously not the case.
For anyone reading this in the future, I switched over to this model and it seems to be working much better with the tool calling:
Mistral-Nemo-Instruct-2407-Q4_K_M
Don’t use qwen2.5-coder models for Home Assistant… in retrospect, I guess it makes sense, as they are weighted for a specific task.
Look at the small gemma4s and qwen35 quants. Whatever reasonably fits in that card. You could probably do 64k context in that 12g on Gemma4:E4B or Qwen3.5:4B (which is an absolute best tool user BTW.)
And yes it was your model. :slight_smile:
Thanks! I’m just starting to learn about all the differences in these LLM models. I’ve been trying to research the best ones for HA, so I appreciate the suggestions!
That Mistral model works well and is fast once responding, but is a little slow on the initial thinking (time to first token). So I will definitely give those others a shot and see what works best.
