LLM Todo Shopping List Sorter
Hi, just want to share my shoppinglist sorter for the store I go at the most.
Since my girlfriend always just throws things randomly on the shoppinglist.
The idea is to read the todo shoppinglist into a csv string then send it to some LLM in my case google gemini since it is free. Ask the LLM to sort it according to a prompt and return it back as csv. Then clear the existing shoppinglist and fill it again from the LLM response.
Works pretty well here.
Change the prompt to your liking offcourse.
Could be a whole lot simpler if there was a native action to move items up or down in a todo list or a clear all items action.
alias: Sort ShoppingList
description: ""
triggers:
  - trigger: conversation
    command:
      - Sort ShoppingList
      - sort shopping list
conditions: []
actions:
  - sequence:
      - variables:
          shoppinglist: null
          sortedshoppinglist: ""
          ai_response: ""
          ai_responselist: []
      - action: todo.get_items
        metadata: {}
          status: needs_action
          entity_id: todo.shopping_list
        response_variable: shoppinglist
      - variables:
          sortedshoppinglist: >-
            shoppinglist['todo.shopping_list']['items']|map(attribute='summary')|join(',
      - action: google_generative_ai_conversation.generate_content
        metadata: {}
          prompt: >-
            Please sort my shoppinglist
            below in the following sortorder Fruits, Vegetables, Pasta,
            Mealboxes, Meat, Chicken, Cheese, Bread, Yogurth, Butter, Milk,
            Eggs, Cereals, Muesli, Coffee, Candy, Soft Drinks, Water, Other. The
            result should be a comma seperated answer containing the original
            items only in the new sort order. My ShoppingList = {{
            sortedshoppinglist }}
        response_variable: ai_response
        enabled: true
      - variables:
          ai_responselist: "{{ ai_response.text.split(', ') }}"
      - repeat:
          count: "{{ shoppinglist['todo.shopping_list']['items'] | length }}"
          sequence:
            - variables:
                item: >-
                  {{ shoppinglist['todo.shopping_list']['items'][repeat.index
                  -1].summary }}
            - action: todo.remove_item
              continue_on_error: true
              metadata: {}
                item: "{{item}}"
      - repeat:
          sequence:
            - variables:
                item: "{{ ai_responselist[repeat.index - 1] }}"
            - action: todo.add_item
              metadata: {}
                item: "{{item}}"
mode: single
Super nice! In case of multiple stores you can create a zone for each store with their own sort order. At the moment you enter the store, sort the list :slight_smile:
Good idea :slight_smile:
Anyway I have to reiterate a bit on the above yaml cause it is not perfect.
A native clear todolist action would fix a lot.
Added continue_on_error for the add and remove items from todolist cause sometimes it failed there.
Also improved prompt a bit so it hopefully the llm does not hallucinate items you did not put on the list :slight_smile:
i’m getting many duplicate, do you?
Yeah now I do, It has to do with the todo list remove item loop.
I think something has changed in HA.
I’ll check if we can do a workaround…
