LMS, play Dynamic playlists created with Dynamic Playlist Creator plugin
Can I use the “squeezebox.call_method” to play dynamic playlists created with the dynamic playlist creator plugin?
I can export a dynamic playlist to a static playlist that I can play but I would like to play the dynamic playlists directly with the “squeezebox.call_method”.
Thanks,
Eric
the wiki page at https://github.com/AF-1/lms-dynamicplaylists/wiki/CLI-commands
seems to provide a method for doing this but so far I’ve been unable to get it to work
But that is probably more to do with my inability to get to grips with yaml and passing parameters
At the moment I have a little script as follows
lms_dynamic_play:
  alias: Lms Dynamic
  mode: single
  icon: mdi:music
  sequence:
  - service: squeezebox.call_query
      command: dynamicplaylist
      parameters:
      - playlist
      - play
      - dplusercustom_TestList
      entity_id: media_player.picoreplayer_2
but it doesn’t seem to do anything other than stop whatever is currently playing on the squeezelite player
any help or hints gratefully accepted
to answer my own question the following script fragment works in my scripts.yaml
lms_dynamic_play:
  alias: Lms Dynamic
  mode: single
  icon: mdi:music
  sequence:
  - service: squeezebox.call_method
      parameters:
      - playlist
      - play
      - dplccustom_guitars
note that the playlist prefix is dplccustom_ ie a double c
and that the actual playlist name is lowercase no matter what you have called it
the following curl command also works
curl -g -X POST -d '{"id":1,"method":"slim.request","params":["b8:27:eb:82:e9:e3",["dynamicplaylist","playlist","play","dplccustom_rocksteady"]]}' http://192.168.XX.YY:9000/jsonrpc.js
if you hover your mouse over the play button for your dynamic playlist you can see how it is called
hope this prevents anyone else tearing their hair out for a few days
A fuller script to do this follows
# in the following array SqueezePlayLists
# you must replace any URL Encoding strings by the actual characters they represent
# for exampe %2b is + and %2f is /
# the string dplstaticpl_PGPBtJ1Dd6Co5RDdrt9%2F%2FJKp1d8
# has to become dplstaticpl_PGPBtJ1Dd6Co5RDdrt9//JKp1d8
lms_dynamic_play:
  alias: Lms Dynamic
  mode: single
  icon: mdi:music
  sequence:
  - variables:
      SqueezePlayLists:
        Dinner: 'dplstaticpl_PGPBtJ1Dd6Co5RDdrt9//JKp1d8'
        Karen: 'dplstaticpl_xXMhdJQR/Up59ZgBx+j4ypsz55k'
        Speaker-Test: 'dplstaticpl_maRsj0ELIYXNTbXiYejkTvghpek'
        Guitars: 'dplccustom_guitars'
        Heavy: 'dplccustom_heavy'
        Long_Songs: 'dplccustom_long_songs'
        My_Folk: 'dplccustom_my_folk'
        My_Jazz: 'dplccustom_my_jazz'
        My_Prog: 'dplccustom_my_prog'
        RockSteady: 'dplccustom_rocksteady'
        Short_Songs: 'dplccustom_short_songs'
        1950s: 'dplccustom_1950s'
        1960s: 'dplccustom_1960s'
        1970s: 'dplccustom_1970s'
        1980s: 'dplccustom_1980s'
        '1969': 'dplccustom_1969'
        '1975': 'dplccustom_1975'
      Item: "{{ SqueezePlayLists[ states('input_select.lmsplaylist_select') ]  }}"
      # parameters: "{{ ['playlist', 'play', item] }}"
      parameters:
      - playlist
      - play
      - "{{ Item }}"
      entity_id: media_player.{{ states('input_select.lms_instance') }}
The only way i have found to obtain the DYNAMICPLAYLIST_ID for a static playlists is by moving the mouse pointer over the play link for a static playlist in
Home > Dynamic Playlists > Static Playlists Menu
and by then copying the link and extracting the DYNAMICPLAYLIST_ID from it
note you must replace any URL Encoding strings by the actual characters they represent
for example %2b is + and %2f is /
the DYNAMICPLAYLIST_ID dplstaticpl_PGPBtJ1Dd6Co5RDdrt9%2F%2FJKp1d8
before you can use this in in any squeezebox_call_method parameters
Update !!!
Having heard from the creator of the LMS DynamicPlayList plugin how the url for static playlists is created
The specific part after dplstaticpl_ is the SHA1 digest of the playlist url as a base64 encoded string. As you have discovered, this ony applies to static playlists. All other dynamic playlists use the filename to create the playlist id
For Example:
Playlist url/path from the LMS database: file:///Users/af1/Music/LMS%20Playlists/Bookmarked%20Tracks.m3u
SHA1 digest of the playlist url as a base64 encoded string: jor13XtXjcbmjwFHTwGGp8xPK1k
Your playlist id for CLI commands: dplstaticpl_jor13XtXjcbmjwFHTwGGp8xPK1k
I have created a little perl script which you can run on your LMS server in the playlists folder, which will generate the correct playlist id for using in scripts
#!/usr/bin/perl
BEGIN {
    push ( @INC,"/opt/logitechmediaserver/CPAN");
use Digest::SHA1 qw(sha1_base64);
$PLAYLIST = "/home/Playlists";
opendir(D, $PLAYLIST) || die "Can't open directory $PLAYLIST: $!\n";
@list = grep /m3u$/, readdir(D);
closedir(D);
foreach my $f (@list)
        $string = "file://" . $PLAYLIST . "/" . $f;
        my $playlistid = 'dplstaticpl_'.sha1_base64($string);
        print "$string - $playlistid\n";
Hope it helps others
I’m trying to play a playlist created by the Dynamic Playlist LMS plug-in, but it’s not doing anything. I don’t get an error message, but executing the script doesn’t do anything on the player.
This is the script:
sequence:
  - data:
      parameters:
        - playlist
        - play
        - dplccustom_random1
      entity_id: media_player.kitchen
    action: squeezebox.call_method
mode: single
This is the playlist which was created by Dynamic Playlist Creator:
lms
Any idea what I might be doing wrong?
