Hi, i know how to load custom components, but now i am interested to test the PR below, its a intergration based on UI, and not yaml … how can we sideload this?
thnx in advance
thnx in advance
I think it’s the same way as with a custom component. Do you not see the integration when you go to Configuration -> Integrations?
no, not sure how todo that
if i look at “files changed” on github, i see several folder/files changed, not just 1 folder to load as custom like other customs components
example :
homeassistant/components/risco/alarm_control_panel.py
homeassistant/components/random/
homeassistant/generated/config_flows.py
homeassistant/components/risco/strings.json
Did you ask the developer how to do it?
It depends quite heavily on how you installed Home Assistant? Supervised? Venv?
he is not sure either, i am running HassOS (esx server)
not so familiar with access rights in Home Assistant OS. Are you able to login to the containers directly and change files there?
not sure, didnt do yet
but i think i just gonna wait,… too bad, wanted to help testing
