Hallo sorry my english is not the best. I will upload my programm my ESP has the depault Programm and is in my WIFI. when i will uploud is come the same error agains. My code is:
esphome:
# friendly_name: Kamera1
esp32:
board: esp32cam
framework:
type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
encryption:
key: "key"
ota:
password: "pass"
wifi:
ssid: ssid
password: pass
ap:
ssid: "etwascam"
password: "pass"
captive_portal:
esp32_camera:
external_clock:
pin: GPIO0
frequency: 20MHz
i2c_pins:
sda: GPIO26
scl: GPIO27
data_pins: [GPIO5, GPIO18, GPIO19, GPIO21, GPIO36, GPIO39, GPIO34, GPIO35]
vsync_pin: GPIO25
href_pin: GPIO23
pixel_clock_pin: GPIO22
power_down_pin: GPIO32
horizontal_mirror: false
vertical_flip: false
output:
- platform: gpio
pin: GPIO4
light:
- platform: binary
output: gpio_4
And my error:
Failed config
wifi: [source :22]
ssid: FRITZ!Box
Must be string, got <class ‘esphome.helpers.EInt’>. did you forget putting quotes around the value?.
password: 7538
ap: [source :27]
Component not found: ap.
ssid: etwascam
password: pass
