Up until two days ago my reverse proxy through ngnix was working fine.
I upgraded Hass and now I can only log in via my local address.
If I attempt to use my url from outside of the network, I can get to the login page, but then it just hangs at “Loading Data”.
I have Letsencrypt setup on my Unraid server (192.168.86.2)
Hass is running on a Nuc with Debien 11 (192.168.86.6)
HTTP section from my config file.
http:
use_x_forwarded_for: true
trusted_proxies:
- 192.168.86.2
- 172.17.0.7
proxy config for Ngnix.
server {
listen 443 ssl;
server_name mysub.*;
include /config/nginx/ssl.conf;
# enable for ldap auth, fill in ldap details in ldap.conf
#include /config/nginx/ldap.conf;
location / {
proxy_pass http://192.168.86.6:8123;
proxy_set_header Host $host;
proxy_http_version 1.1;
proxy_set_header Upgrade $http_upgrade;
proxy_set_header Connection "upgrade";
location /api {
proxy_pass http://192.168.86.6:8123/api/websocket;
It appears as though the proxy is working, but seems like something in HA is blocking it.
Any help is appreciated.
