It means that manually configuring those cameras via a yaml config entry is no longer accepted. You can only configure that integration thru the UI from now on. But the yaml configuration was automatically imported to the UI config.
Now you just need to remove the yaml config for the foscam integration to remove the warning message.
It was in the breaking changes for the latest release.
I only can connect one of my foscam cameras since version 2021.2.1. Why should we connect with rstp on port 554 ? All was working with yaml configuration then not working on version 2021.2.0 then working on version 2021.2.1 and last two updates only one camera is working. If second camera is connected the two cameras appear with broken connection … A solution is appreciated. Thanks in advance
I’m sorry I don’t have any solutions for you. All of my cameras are working fine. But I’ve had them configured for a while in the UI (moved from yaml config a while back).
You could try to post an issue on github for that integration. Or try to get help on discord.
Thank you for your answer but is not possible to leave the field rstp port 554 optative? On version 2021.2.1 the field is not there and the two cameras are working OK…
