I tried to find out why I get this in my home-assistant.log:
“Loading Met.no via platform config is deprecated”
How do I fix this?
remove from configuration.yaml and add the met.no integration via configuration > integrations in the UI
Of course! Why didn’t I think of that? Thank you
I do not have the ‘met’ platform (https://www.home-assistant.io/components/met/) in my configuration.yaml but get this message too. Is there something else which included this platform which I have to remove from the configuration.yaml?
The same here.
Nothing in the configuration file regarding met.no, still getting Loading Met.no via platform config is deprecated.
I’ve ran ack to search for anything on my server regarding met.no, no results.
Same here. Nothing that I can find referencing Met.no but I am also getting the error.
