I am loading a couple of nodes from GitHub via the configuration;
npm_packages:
- node-red-admin
- git+https://github.com/borpin/node-red-contrib-fitbit2.git
The issue is that the nodes are then saved in /opt
rather than locally in /opt/config/node-red/node_modules
where (it seems) nodes installed via the palette are saved.
The knock on, is that if the node tries to write a file, it defaults to /opt
rather than the user directory.
Is this location by design or a bug?
