Hey,
i am new in HA and YAML, i tried a lot now and didn’t find my misstake.
current test setup:
- 1x PIR sensor (PIN 33, 27k Pull-Down)
- 1x LEDC driver (PIN 25)
- 1x touch button (PIN 34, 27k Pull-Down)
What is working:
- I see PIR in HA
- I can switch and dim LED via HA.
What is not working:
- on_click to activate the light with PIR
My final goal:
If PIR (on time 15 sec) is detect movement switch on the LED for 2 min with 50% brightness.
If PIR has detecting in between the LED is on, restart the 2 min timer.
IF a touch botton is used don’t use the PIR (second step)
esphome:
friendly_name: s73_aut
esp32:
board: az-delivery-devkit-v4
framework:
type: arduino
logger:
level: VERY_VERBOSE
api:
encryption:
key: "!"
ota:
- platform: esphome
password: "!"
wifi:
ssid: !secret wifi_ssid
ap:
ssid: "S73-AUT"
password: "!"
captive_portal:
# --- GLOBALS VARIABLE --- maybe i need this way
globals:
- id: actual_effect
type: int
restore_value: yes
initial_value: '0'
# --- I2C CONFIG working ---
i2c:
sda: 21
scl: 22
scan: true
# --- Analog IC working ---
ads1115:
- address: 0x4A
i2c_id: bus_a
# --- END Analog IC ---
# --- END I2C CONFIG ---
# --- SENSORS ---
# --- WIFI SIGNAL --- working
- platform: wifi_signal # Reports the WiFi signal strength/RSSI in dB
name: "WiFi Signal dB"
update_interval: 60s
entity_category: "diagnostic"
- platform: copy # Reports the WiFi signal strength in %
source_id: wifi_signal_db
name: "WiFi Signal Percent"
filters:
- lambda: return min(max(2 * (x + 100.0), 0.0), 100.0);
unit_of_measurement: "Signal %"
# --- END WIFI SIGNAL ---
# --- DISPLAY uptime working ---
- platform: uptime
# --- END DISPLAY uptime
# --- RESTART Button --- working
button:
- platform: restart
# --- END RESTART Button ---
# --- BINARY SENSOR PIR ---
binary_sensor:
- platform: gpio
pin:
number: 33
mode:
input: true
pulldown: true
name: "PIR Sensor outside"
device_class: motion
on_click:
then:
- light.turn_on: light_left
- output.set_level:
level: "50%"
filters:
- delayed_off:
seconds: 15
# --- END BINARY SENSOR PIR ---
# --- OUTPUT LEDC --- working
output:
- platform: ledc
pin: 25
frequency: 1000Hz
# --- END OUTPUT LEDC
# --- LIGHT CONFIG --- working
light:
- platform: monochromatic
output: light_left_PWM
restore_mode: ALWAYS_OFF
# --- END LIGHT CONFIG ---
