Local Devices bypassing SSL?
Hi All,
I’m using a Konnected alarm system with HA.
Issue i’m having is that as i’ve got SSL set up the duckdns, my Konnected panel operates very slowly when passing through the https:// api.
So on the config i’ve request it ignore the host api and use the local ip address for access. This isnt working though.
Any ideas?
I had a similar tech issues but with different origins/cause… I am now using a reverse proxy for https
external stuff, internal goes through http
How???
I’ve set up duckdns. How to i set up nginx etc so the internal items can use http://?
Here I have no support, sorry for that, I use my synology as reverse proxy (yeah… I know, should not eetc. :slight_smile: ) . There are plenty posts/instructions on how to do so but (as per above) I do not follow these.
Thanks.
I found one. I’ve followed quite a few before but had that much mess going on i just needed to start from scratch!
Thanks anyway
If you set up ngix correctly, they will.
Yeah sorted it. Thanks
