Thanks for the attempt at helping, but i was done troubleshooting this ever since pascal vizeli agreed there was an issue in coredns at cause. Nothing I - lowly user - can do about this.
Also, I have zero mDNS issues, I use Esphome a lot without problems. Esphome uses mDNS extensively.
If that were the case, you would’ve assigned a local name for every ESPhome device.
It looks like ESPhome uses MQTT for discovery. From their website:
" The esphome <CONFIG> hass-config command shows an auto-generated Home Assistant configuration for the ESPHome node configuration file. This is useful if you’re not using MQTT discovery."
Seriously, I’m not trying to pile on; that wouldn’t be helpful. And I’m a lowly user, myself. Peace.
*ESPHome uses a native api & most certainly not mqtt for discovery and/or communication with HA,
*ESPHome can also use mqtt if you want to, but mostly i don’t use it snce the api works wonderfully,
*ESPHome + the api usage does indeed assign a hostname to each and every single node you create,
*Every communication between HA & the ESPHome node uses this hostname, i’m guesstimating there’s thousands of lookups for those hostnames happening on my lan every day.
Sorry, I thought it could be related to the inability to resolve local hostnames. One thing I’ve seen is the use of .local rather than something else, like .mylocal (which I use). It’s just something to consider. Obviously, if your local DNS resolver is somehow getting bypassed, it’s a moot point.
The following is from my router documentation, and applies to the Unbound DNS implementation used in my router. Whether it also applies to CoreDNS is not known to me.
“Do not use ‘.local’ as the final part of the domain (TLD), The ‘.local’ domain is widely used by mDNS (including Avahi and Apple OS X’s Bonjour/Rendezvous/Airprint/Airplay), and some Windows systems and networked devices. These will not network correctly if the router uses ‘.local’. Alternatives such as ‘.local.lan’ or ‘.mylocal’ are safe.”
yes, .local is supposedly “reserved” for mDNS, yet OpenWRT, Pi-hole, and millions of standard Debian installations use .local as the default suffix for the hostname.
Who am I to go against the stream ?
.local just works ™ in every. single. network. i’ve ever managed.
I just followed the guidance for the router and only used the .mylocal in the setting for the router. I can ping any device on the network using either .local or .mylocal. I can’t claim this is any magic sauce, but things are working. YMMV.
I’ve been trying to understand some things regarding networking and just stumbled on something useful. Its use has been discussed within the community forum, but it’s new to me. This is FYI for those who might need to look under the hood.
Aside from the CLI interface for Home Assistant (https://www.home-assistant.io/hassio/commandline/), an instance of BusyBox is included. It’s a single executable with a useful palette of utility commands.
Hi! I’ve found this thread and I’ve one of the problems commented here:
All my local addresses are not being resolved
My router acts as DNS and it contains a name for every device on my network. Some of them added automatically, others manually by me.
Until some weeks ago the names were resolved without problem by Home Assistant, now this is not true anymore at least for some petitions, and I need to add an IP directly for that.
Others computers in the network resolve them perfectly, asking to the default DNS, my router, but seems that Home Assistant is not doing that.
Some of you, that have a similar problem, found a solution for this?
As you can see, the address is finding the correct IP (192.168.100.20 in this case), but it throws an NXDOMAIN error later that produces that this IP is discarded and not used. Maybe someone with more experience can explain that.
I’ve found a workaround modifying the coredns template… I don’t know if this can have some drawbacks, but it seems to work and I have not found any problem until now.
In the hassio_dns docker, that contains the coredns server, there is a template file with the configuration of the coredns. I’ve modified that:
template ANY AAAA local.hass.io hassio {
rcode NOERROR
adding my local domain (piminet) at the end:
template ANY AAAA local.hass.io hassio piminet {
rcode NOERROR
In this way it returns NOERROR in place of NXDOMAIN and now it works and resolves the local domains without problem, at least in my case .
If this solution is ok, maybe some real Home Assistant developer can add a new option to the ha dns CLI command to add the local domain here automatically.
Local network DNS is now my biggest issue.
I’m running a local network with MS AD delivered through MS DNS, clients config delivered through MS DHCP. MS DNS servers configured with just pfsense resolver as forwarder. Pfsense DNS Resolver configured with 1.1.1.1 and 9.9.9.9 over tls with dnssec enabled.(DNS has run well for couple of years on that config.
My IoT is running on 2 separated Vlans much like Rob’s (The Hookup). DNS for those devices delivered through PFSense resolver and client configs delivered via PFSense DHCP.
Things were working until recently but having made so many changes to get things working, I’m at the head-scratching moment…or does that come again later, feel like head has received much scratching lately.
Anyway, MS domain was running as “.home.ba.local". This has worked issue-less for 20 years.
My iot domain has been set to ".not.ba.local.lan” as I’m told using .local is a bad idea.
I’ve configured HA to use pfsense as the primary dns but it just doesn’t resolve local devices.
I have the feeling we’re close but just need a little more granular control over configs. Not all home lans are setup with straight forward configs and while I appreciate the impossibility of trying to support all possible configs, we just need to work together to make this robust.
this, totally.
now…rest assured, using .local is not a bad idea (whatever some people ‘in-the-know’ around here are claiming).
also…dns in Home Assistant is broken since the apparition of CoreDNS, but ‘they’ (those Ivory-tower devs) are pointing fingers to ‘our’ (lowly users) bad network configurations. Problem is, there’s more & more people starting to complain.
but…personally I’ve given up the fight, and am doing a ha restart dns every so often, according to a developer this is something I’ll just have to live with. Looking at you, @pvizeli .
@balloob The community is still the greatest I’ve ever seen - for an open source project, but the top of the pyramid…ehh…not so much.
Can ya tell I’m frustrated ?
there is more than a single thing wrong with hass.io
Remember one of the Head is from switzerland and parts of the swiss speaks german.
In German the word hass is the same as the word hate in english
if you didnt want to add a cronjob with something like docker exec -it homeassistant sh -c 'echo nameserver 8.8.8.8>/etc/resolv.conf'
you need to run this ecerytime ha is restarted.
So vest way is to take YOUR HA setup in YOUR HANDS and smile the mistakes from these “Developer skriptkiddies” away.
HA without HASS works like a charm eg. things like tasmoadmin runs fine you just need to dig into the manuals.
cheers
(OT)
Nice catch
But if your looking carfully you might notice that i own a new Notebook with another keyboardlayout and some of the chars are one key offset.
Ich hasse dich (now the Noun becomes a adjektive)
TbH i really dont know if i called one of the “two” guys a scriptkiddie because everything worse i noticed was from only one of them.
eg. the Pulse Audio BS. AFAIK THAT must be the Swiss Guy.
(/OT)
I strongly disagree with branding the devs as scriptkiddies. The software they are building clearly demonstrates they are in no way scriptkiddies. I would brand some of them as ‘haughty & detached from the userbase.’
I migrated from a Supervised install to Home Assistant OS for simplicity & easy of management. Little did I know that DNS in HA-OS is broken & classed as wont-fix-stop-complaining by the dev in charge.
DNS being the only major gripe I have, I’ll stick with ha dns restart untill it gets fixed, or untill it gets broken even more.
