#this is configuration.yaml code
homeassistant:
# HA접속시 표시되는 이름
whitelist_external_dirs:
- /config/www/images
# Configure a default setup of Home Assistant (frontend, api, etc)
default_config:
#local_file_update_file_path:
#file_path: /config/www/images/cam_snapshot.jpg
# Example configuration.yaml entry
camera:
- platform: local_file
file_path: /config/www/images/snapshot.jpg
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# http:
# base_url: example.duckdns.org:8123
# Text to speech
tts:
- platform: google_translate
#this is script.yaml code
script:
snapshot_cam:
sequence:
- condition: state
entity_id: camera.lubacam
state: 'idle'
- service: camera.snapshot
data_template:
# this is automation.yaml code
automation:
- alias: last motion time
initial_state: 'on'
platform: state
entity_id: binary_sensor.motion_CGB
to: 'on'
- service: script.snapshot_cam
- service: camera.local_file_update_file_path
data_template:
entity_id: camera.local_file
I want to save screenshot in my local folder. but “Could not read camera lubacam_snapshot image from file: /config/www/images/snapshot.jpg” error log…
thank you for your reply
