Hello all,
I used the morning to generate more local data for my dashboard. Through the tip of hsch0 I came across the data of the water level of the Rhine. Conveniently, the “Wasserstraßen- und Schifffahrtsverwaltung des Bundes” also offers a nice API with JSON output
I have not yet worked up all the data in my Lovelace card and am always happy to receive tips and suggestions for improvement.
With the data, notifications about high and low water are of course also very feasible
Dataset:
Helpful Tools:
- JSONPath Online Evaluator: https://jsonpath.com/
- JSON-Selector: http://jsonselector.com/
Parse RESTful JSON-Data:
- platform: rest
name: "Pegel Cologne Wasserstand"
resource: https://www.pegelonline.wsv.de/webservices/rest-api/v2/stations/K%C3%96LN.json?includeTimeseries=true&includeCurrentMeasurement=true
json_attributes_path: $.timeseries[0].currentMeasurement
json_attributes:
- timestamp
- trend
- stateMnwMhw
- stateNswHsw
value_template: '{{ ( value_json.timeseries[0].currentMeasurement.value | int / 100 ) }}'
unit_of_measurement: "m"
- platform: rest
name: "Pegel Cologne Abfluss"
json_attributes_path: $.timeseries[1].currentMeasurement
json_attributes:
- timestamp
value_template: '{{ value_json.timeseries[1].currentMeasurement.value }}'
unit_of_measurement: "m³/s"
- platform: rest
name: "Pegel Cologne Temperatur"
json_attributes_path: $.timeseries[2].currentMeasurement
json_attributes:
- timestamp
value_template: '{{ value_json.timeseries[2].currentMeasurement.value }}'
unit_of_measurement: "°C"
Generating some more Sensors from the data:
sensors:
sensors:
pegel_cologne_wasserstand_trend:
friendly_name: "Trend"
value_template: >-
{% if states.sensor.pegel_cologne_wasserstand.attributes.trend == 1 %}steigend
{% elif states.sensor.pegel_cologne_wasserstand.attributes.trend == 0 %}gleichbleibend
{% elif states.sensor.pegel_cologne_wasserstand.attributes.trend == -1 %}fallend
{% else %}unbekannt{% endif %}
icon_template: >-
{% if states.sensor.pegel_cologne_wasserstand.attributes.trend == 1 %}mdi:trending-up
{% elif states.sensor.pegel_cologne_wasserstand.attributes.trend == 0 %}mdi:trending-neutral
{% elif states.sensor.pegel_cologne_wasserstand.attributes.trend == -1 %}mdi:trending-down
{% else %}mdi:water{% endif %}
pegel_cologne_wasserstand_state:
friendly_name: "Aktuell"
value_template: >-
{% if states.sensor.pegel_cologne_wasserstand.attributes.stateMnwMhw == 'low' %}Niedrigwasser
{% elif states.sensor.pegel_cologne_wasserstand.attributes.stateMnwMhw == 'normal' %}Normal
{% elif states.sensor.pegel_cologne_wasserstand.attributes.stateMnwMhw == 'high' %}Hochwasser
icon_template: >-
{% if states.sensor.pegel_cologne_wasserstand.attributes.stateMnwMhw == 'low' %}mdi:down-up-box
{% elif states.sensor.pegel_cologne_wasserstand.attributes.stateMnwMhw == 'normal' %}mdi:arrow-right-box
{% elif states.sensor.pegel_cologne_wasserstand.attributes.stateMnwMhw == 'high' %}mdi:arrow-up-box
pegel_cologne_wasserstand_schiffahrt:
friendly_name: "Schiffahrt"
value_template: >-
{% if states.sensor.pegel_cologne_wasserstand.attributes.stateNswHsw == 'low' %}Zu wenig Wasser
{% elif states.sensor.pegel_cologne_wasserstand.attributes.stateNswHsw == 'normal' %}Normal
{% elif states.sensor.pegel_cologne_wasserstand.attributes.stateNswHsw == 'high' %}Zu viel Wasser
icon_template: mdi:ferry
homeassistant:
customize:
sensor.pegel_cologne_wasserstand:
friendly_name: Wasserstand
icon: mdi:arrow-expand-vertical
sensor.pegel_cologne_abfluss:
friendly_name: Abfluss
icon: mdi:water
sensor.pegel_cologne_temperatur:
friendly_name: Wassertemperatur
icon: mdi:coolant-temperature
Lovelace-Code
type: vertical-stack
cards:
- type: entities
entities:
- entity: sensor.pegel_cologne_wasserstand_state
- entity: sensor.pegel_cologne_wasserstand_trend
- entity: sensor.pegel_cologne_temperatur
header:
type: picture
image: local/img/header_pegel.png
tap_action:
action: none
hold_action:
action: none
- entities:
- sensor.pegel_cologne_wasserstand
hour24: true
type: 'custom:mini-graph-card'
hours_to_show: 168
points_per_hour: 0.5
Lovelace-Card
Have fun!
