I see nothing in the logs after I try to play the file.
Edit.
If I would play something under Media, Sonos I got this error in the logs:
Protokolldetails (FEHLER)
Logger: homeassistant.components.websocket_api.http.connection
Source: components/sonos/helpers.py:78
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 21:01:33 (3 occurrences)
Last logged: 21:01:55
[547205837968] Error calling SonosMediaPlayerEntity._play_media on media_player.wohnzimmer: UPnP Error 800 received: from 192.168.178.75
File "/usr/src/homeassistant/homeassistant/components/sonos/helpers.py", line 64, in wrapper
result = funct(self, *args, **kwargs)
File "/usr/src/homeassistant/homeassistant/components/sonos/media_player.py", line 554, in _play_media
self._play_favorite(favorite)
File "/usr/src/homeassistant/homeassistant/components/sonos/media_player.py", line 446, in _play_favorite
soco.add_to_queue(favorite.reference, timeout=LONG_SERVICE_TIMEOUT)
File "/usr/local/lib/python3.11/site-packages/soco/core.py", line 148, in inner_function
return function(self, *args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/soco/core.py", line 2223, in add_to_queue
response = self.avTransport.AddURIToQueue(
File "/usr/local/lib/python3.11/site-packages/soco/services.py", line 206, in _dispatcher
return self.send_command(action, *args, **kwargs)
File "/usr/local/lib/python3.11/site-packages/soco/services.py", line 514, in send_command
self.handle_upnp_error(response.text)
File "/usr/local/lib/python3.11/site-packages/soco/services.py", line 567, in handle_upnp_error
raise SoCoUPnPException(
soco.exceptions.SoCoUPnPException: UPnP Error 800 received: from 192.168.178.75
File "/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py", line 205, in handle_call_service
await hass.services.async_call(
File "/usr/src/homeassistant/homeassistant/core.py", line 1910, in async_call
task.result()
File "/usr/src/homeassistant/homeassistant/core.py", line 1950, in _execute_service
await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
File "/usr/src/homeassistant/homeassistant/helpers/entity_component.py", line 226, in handle_service
await service.entity_service_call(
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 811, in entity_service_call
future.result() # pop exception if have
File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 1034, in async_request_call
await coro
File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 851, in _handle_entity_call
await result
File "/usr/src/homeassistant/homeassistant/components/sonos/media_player.py", line 539, in async_play_media
await self.hass.async_add_executor_job(
File "/usr/local/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/src/homeassistant/homeassistant/components/sonos/helpers.py", line 78, in wrapper
raise SonosUpdateError(message) from err
homeassistant.components.sonos.exception.SonosUpdateError: Error calling SonosMediaPlayerEntity._play_media on media_player.wohnzimmer: UPnP Error 800 received: from 192.168.178.75
