I want to use cloudmqtt also next to mosquitto.
I have hassio so not much to configure
I can also log in as develop and with docker open the mosquitto to edit things but after restart all edits are gone
any advice?
metbril
(Robert 🇳🇱🇪🇺)
March 5, 2018, 10:00pm
2
The docs tell you where you can store persistant configuration:
# Home Assistant Add-on: Mosquitto broker
MQTT broker for Home Assistant.
![Supports aarch64 Architecture][aarch64-shield] ![Supports amd64 Architecture][amd64-shield] ![Supports armhf Architecture][armhf-shield] ![Supports armv7 Architecture][armv7-shield] ![Supports i386 Architecture][i386-shield]
## About
You can use this add-on to install Eclipse Mosquitto, which is an open-source (EPL/EDL licensed) message broker that implements the MQTT protocol. Mosquitto is lightweight and is suitable for use on all devices from low power single board computers to full servers. For more information, please see [mosquitto].
[aarch64-shield]: https://img.shields.io/badge/aarch64-yes-green.svg
[amd64-shield]: https://img.shields.io/badge/amd64-yes-green.svg
[armhf-shield]: https://img.shields.io/badge/armhf-yes-green.svg
[armv7-shield]: https://img.shields.io/badge/armv7-yes-green.svg
[i386-shield]: https://img.shields.io/badge/i386-yes-green.svg
