I’m running Home Assistant in a Hyper-V VM with a bridged network setting. Based on my testing here’s what I’ve observed:
http://homeassistant:8123 # Works fine
http://homeassistant.lan:8123 # Also works fine
http://homeassistant.local:8123 # Doesn’t work
All of my esphome devices work with all three methods though.
But unfortunately when I go into esphome in the Home Assistant UI all of my devices show up as “offline”, because it’s trying to access them on the .local address which it doesn’t seem to understand.
How can I either:
A. Make home assistant understand .local DNS names
B. Switch it to use the .lan names instead for esphome
