I’ve been working on this, but still have a ways to go. I have a Tempest weather station and am working on current weather conditions based solely on info from my station.
Establishing order of checks (priority):
‘lightning-rainy’ 10 < (sensor.wf_lightning_count_3_hours < 450 (attempt to eliminate false reports from noise on detector) & sensor.wf_precipitation_type > 0
‘lightning’ 3 hour lightning count 10 < (sensor.wf_lightning_count_3_hours < 450 (attempt to eliminate false reports from noise on detector) & sensor.wf_precipitation_type > 0
‘hail’ sensor.wf_precipitation_type = 2
‘snowy-rainy’ sensor.wf_precipitation_type > 0, sensor.wf_temperature = 32F / 0C
‘snowy’ — snowy is a guess since there is no ‘sensor’ that detects snow
(temperature in C) sensor.wf_temperature < 1.44 - 0.08 * sensor.wf_humidity)
(temperature in F) sensor.wf_temperature < 34.29 - 0.14 * sensor.wf_humidity)
and
sensor.wf_temperature < 40F / 4.44C
and
sensor.wf_illuminance < 1000 if sun angle > 0
‘pouring’ sensor.wf_rain_rate > 0.31 in/hr (7.8 mm/hr) or sensor.wf_precipitation_type = 3
‘rainy’ sensor.wf_precipitation_type = 1
‘windy-variant’ Wind Speed > 25mph (11.17 m/s) & cloudy
‘windy’ Wind Speed > 25mph (11.17 m/s)
‘fog’ Fog is likely when:
Air Temperature - Dew Point < 4.5F (2.5C)
Relative Humidity > 95%
Wind Speed (above) > 5 knots / 5.7 mph / 2.57 m/s
Wind Speed (below) < 10 knots / 11.5 mph / 5.14 m/s
Clear skies overnight (???) maybe from Pressure
'> -40F (typically >14F)
*** near seawater >70% Relative Humidity and wind speed <10 knots (5.14 m/s)could cause fog (might skip this caveat for now)
Need more conditions for fog, it looks like this might throw a lot of false fog.
There is some trends for heating/cooling but most would not have a derivative sensor for air temperature.
Cooler air temp than ground temp, determine if daily temp max (24hr) is greater than current temp (more to come)
–Use visibility calculation as condition
‘cloudy’ reduced luminescence with a steady tread
‘partlycloudy’ trend of alternating lower and higher lux
‘clear-night’ sun angle < 0 and no other events
‘sunny’ no other events and sun angle > 0 (minimum of 10,000 lux)
‘exceptional --?? (looked at some weather cards and does not seem to be used)
Need to look at more data and adjust for latitude and time of day.
0.0001 lux – Moonless, overcast night sky.
0.002 lux – Moonless clear night sky with airglow.
0.27–1.0 lux – Full moon on a clear night.
3.4 lux – Dark limit of civil twilight under a clear sky.
100 lux – Very dark overcast day.
400 lux – Sunrise or sunset on a clear day.
1000 lux – Overcast day
10000–25000 lux – Full daylight (not direct sun).
32000–100000 lux – Direct sunlight.
